Can't Select T, R, S, U (Rotate, Manipulate, Translate, etc), why?
This is my second day trying to learn Hexagon, and as I went to rotate and object by pressing R, nothing happened.I've tried selecting several objects as well as trying to create new objects, and it's still the case. I took a screenshot of my entire screen so you could see everything to see if I have something I need to have clicked. Hope someone sees this.
  • AscaniaAscania Posts: 1,855
    Hit <Space>, then try again.
  • WitchavenWitchaven Posts: 34
    ha thank you! I found my own fix to this, I just went to File > User Resources > Reset All which got me back on track. But your way is a thousand times better, so thank you! =)
  • NovaNova Posts: 315
    edited June 2024
    The problem was the ghost mode they clicked on. They can see the object, but they can't grab it and move or rotate it. However, it is a useful function when building. Have fun with Hexagon
    Post edited by Nova on
    I suspect not so much clicked as hitting the spacebar without noticing.
    edited June 2024
    Yes, that could be because the space bar is used to select ghost mode.... Correct
