Learning the Shader Mixer
Celexa
I'm attempted to recreate a material from Poser in the shader mixer. Full disclosure, I've never used the shader mixer before and I'm having trouble finding some functions/channels? that are in Poser. These are the current names I'm having trouble finding in the DAZ shader mixer.
- ColorRamp_2
- Scatter
- Fractal_Sum - I assume this is sum?
- Anisotropic
- Transparency - I assume this is opacity?
- Translucence value - I found translucence under Lighting, but I only see an option for color. Is there an option for strength?
- Hightlight Size
Are you creating a 3Delight or Iray shader? 3Delight should be fairly similar for the most part, but iray si very different.
Fractal Sum is under the Texture group for 3Delight; Scatter would, I guess, be SubSurface Scattering - for 3delight the equivalent is under Lighting>Ray tracing. There isn't an isotropy brick, it is available in the DAZ Material brick when lighting mode is set to Metal. Colour Ramp used t have an equvalanet, the nearest looking think is Mathematical>Spline but I'm not at all familiar with that so hesitate to plug it.
Yes, Opacity would be Transparency - just going from the opposite end. Both Opacity and Translucence use a colour, not a value, so that they can be controlled for the three colour channels separately - pure red, for example would be a value of 100% for red and 0% for green and blue.
Highlight Size is Glossiness, the higher the glossiness the smaller the highlight (rought surfaces spread the highlight out).
Thank you. I planned on starting with 3Delight and maybe moving to Iray later once I have a better understanding of Iray and an Nvidia gpu.
