Older hair
Kev914Kev914 Posts: 1,129
I have a lot of hair products for non-genesis figures. I figured they wouldn't fit the newer characters. But today I tried on on Michael 6 and it seemed to fit him without me doing anything. It even moved with Michael as I posed him. That was a nice surprise. Or maybe I just got lucky? Or does the autofit work with hair too...but I never saw it run or ask me who the hair was originally for.
  • fixmypcmikefixmypcmike Posts: 19,707
    Conforming (cr2) hair will autofit, prop (hr2 or pp2) hair just need to be positioned and possibly scaled, then parented to the head.
  • TimbalesTimbales Posts: 2,428
    Autofit will work for hair that is a Figure, but not hair that is a Prop. You can fit older hairs with a little patience and tweaking.
    What I do is load my person figure, then load in the hair prop. Then I make everything but the hair cap invisible. Then I use the parameter's dials to adjust the position. Then I'll go to Edit-Object-Geometry and create a smoothing modifier. I set the person as the object to collide with. Then I adjust the scale of the hair cap so that it fits the head without too much stretching from the smoothing modifier. Once it fits, I make sure to parent the hair to the figure's head.
    Then I can apply whatever material's preset I want and make little adjustments as needed. Hope this helps.
  • kyoto kidkyoto kid Posts: 42,046
    ..that's pretty much what I do as well.  Even if the hair will fit by simply clicking "fit to". I so it manually as I have seen weight mapping have an adverse effect on hair morphs and poses of some older styles, especially those that have a lot of parameters.
    Been manually cross-fitting hair since I got into this years ago.
  • JPayneJPayne Posts: 79
    edited August 2015
    I never use auto-fit for any type of hair. I just select nothing and load a conforming or prop hair into the scene, parent it to the head dial all the x,y and z to 0 and rescale if needed. You avoid that vacuum effect totally and can pose it with more freedom.
    Post edited by JPayne on
    i been tryin to recognize this long hair a few days now, fail crying
    the long brunette hair? That looks like Sapphire Fox hair to me.
  • Kev914Kev914 Posts: 1,129
    The hair I used was Darryl. I think it was in the Hair folder. But I'll save the information you provided for when I find one that doesn't fit automatically.
    Yes, Daryl is a prop hair.
    Thanks.
    the product page for sapphire hair is confusing.
  • SixDsSixDs Posts: 2,384
    "the product page for sapphire hair is confusing"
    You found a product page for Sapphire Fox? I thought it had been discontinued (it was for V3).
    can't tell if it's just inj files or if it comes with the geometry?
    https://www.daz3d.com/sapphire-fox-dreamy-morphs-and-styles
    That appears to have a version of Sapphire Fox hair, but only the morphs created for this specific package. It doesn't have any of Quarker's original morphs. I'm guessing the vendor may have made a deal with Quarker to get the hair prop that is included.
  • TSasha SmithTSasha Smith Posts: 27,371
    Mileage may vary depending on the hair.
    I thought this was about hair for older people.
  • ArtiniArtini Posts: 10,438
    edited August 2015
    Sapphire Fox hair is one of my favorites as well.
    Below is an iray render of Victoria 7 with Sapphire Fox hair.
    1024 x 1024 - 227K
    Post edited by Artini on
