imported in obj format and moves separately from the facial expression
kasanoba55kasanoba55 Posts: 6
edited June 2024 in Daz Studio Discussion
I imported the eyelashes created in Zbrush into the Daz character using goz.
However, it is imported in obj format and moves separately from the facial expression even if you set it as a parent.
Is there a solution??
  • felisfelis Posts: 6,523
    There isn't a proper bone to parent the eyelashes to, so it will follow all poses.
    So you would normally use transfer utility.
  • crosswindcrosswind Posts: 10,281
    Pls firstly confirm the process you did :
    You exported eyelashes from DS to Zbrush via GoZ, sculpted them then send back to DS as a morph ? Or, you just made a pair of eyelashes in ZB, then sent it to DS via GoZ ?
