Migrating Daz to new system
Hello all,
Forgive me if this has been asked before.
I have finally built a better machine for my rendering. But I did a lot of work on my old machine. Specifically, I saved a lot of poses in the Daz library.. As well as some custom items in my "local user" area.
Plus, I moved my "Daz Library" to a secondary disk.
Sure, I can download Daz, and get it running, that's not a real problem.
It's all the custom, personalized data that I'm worried about.
Do I simply copy directories from old machine to new, and it'll just show up? Or is there more that I need to do..
Thanks in advance.
Check these threads :
https://hpclscruffy.daz3d.com/forums/discussion/562336/moving-the-my-daz-3d-library
https://www.daz3d.com/forums/discussion/comment/8183236/#Comment_8183236
https://www.daz3d.com/forums/discussion/comment/8744341/#Comment_8744341
Either move the old HDD over to the new maching and tell DS to look over there or simply copy the entire library to a external disk and then copy it to the new machine and tell DS where to look,
Option 1 is not for everyone but the easiest method (did that last time myself) where as option two takes a lot more time and if you dont have USB3 ports, it can take forever (24 hours last time I did it just to copy over USB2 ports and 1 hour to the new machine over USB3)
Thanks..
I was a little worried about the "custom content".... but copying the disks worked a treat...
The nit-picky part was going into both DIM and DAZ and setting all the disk/directory paths correctly. Everything's working fine now.
Thanks, again.
