Issue with content not loading right
Can someone please tell me how to fix this problem I'm having? Ok, I get gray square blocks as content.as in the picture I included. Now that is suppoed to be the Black Panther for Big Cats 2 cryinglol,. Hopefully someone can help correct this. And fyi, I am running Daz 4.8 x64
  • fixmypcmikefixmypcmike Posts: 19,706
    How did you install the Big Cat 2, and where?  I assume the Big Cat 2 loads that way also?
  • I installed it in my main content folder C:\Users\Public\Documents\My DAZ 3D Library and also tried C:\Users\*-*\Documents\DAZ 3D\Studio\My Library. Same results. And yes you are correct the whole package loads that way. Its all Bad
  • Did you renmove the items from the Content folder in the zip? You don't want that.
  • Only when I tried them in the C:\Users\*-*\Documents\DAZ 3D\Studio\My Library folder since The original install failed  that was done by Daz Install Manager. Here is a copy of the log of its install
    800 x 800 - 143K
  • I don't see any mention of the DAZ Big Cat 2 itself in your log.
    Your software install path is also wrong, but that's unrelated.
