Daz Studio 4.22 won't install
I guess the image tells enough. I tried yesterday multiple times, I tried now too. Nothing happens. I don't even dare to touch the Beta version. It's sad that this even happens, because Daz got downloaded, does the installing, but does not do it and does not show up or throw out an error.
  • frank0314frank0314 Posts: 14,788
    Try installing Daz Studio from the Ready to Install tab if it works to see where an error may be occuring. What does your error report say? Cog wheel upper right corner "Show Log".
  • Richard HaseltineRichard Haseltine Posts: 109,523
    That pop-up will appear, unless you disable it, if any of the packages it conatins remain uninstalled - it may not mean the application is not installing.
  • gniiialgniiial Posts: 230
    That is how it looks like
    Log
    2024-06-02 18:43:01.423 [INFO] :: Download Successful: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 18:43:01.465 [VERBOSE] :: Saving Adjacent Package Supplement: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 18:43:01.466 [INFO] :: Installing: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 18:43:04.888 [WARNING] :: QProcess: Destroyed while process is still running.
    2024-06-02 18:43:06.310 [INFO] :: Install Successful: DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 18:43:06.368 [VERBOSE] :: Removed Package: IM00013176-02_DAZStudio422Win64bit.zip
    2024-06-02 18:43:06.368 [VERBOSE] :: Removed Adjacent Package Supplement: IM00013176-02_DAZStudio422Win64bit.dsx
    2024-06-02 18:43:06.370 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:43:06.482 [INFO] :: Install Queue Finished: 0 min 5.0 sec
    2024-06-02 18:44:15.188 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:15.239 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:15.378 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:15.427 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:15.527 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:15.634 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:20.859 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:23.451 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:23.464 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:23.572 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:30.406 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:30.523 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:35.611 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:36.880 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:36.980 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:39.022 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:44:39.075 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:45:42.689 [VERBOSE] :: Requesting keep-alive...
    2024-06-02 18:45:43.663 [VERBOSE] :: Keep-alive successful
    2024-06-02 18:45:43.663 [VERBOSE] :: Requesting current notification data...
    2024-06-02 18:45:43.663 [VERBOSE] :: Requesting default notification data...
    2024-06-02 18:45:44.164 [VERBOSE] :: Local cache contains default notification data
    2024-06-02 18:45:44.200 [VERBOSE] :: Local cache contains current notification data
    2024-06-02 18:46:38.802 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:46:38.862 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:46:38.916 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:46:39.060 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:46:39.110 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    2024-06-02 18:46:40.066 [WARNING] :: Open Install Manifest Failed - The file could not be opened: C:/Users/Public/Documents/DAZ 3D/InstallManager/ManifestFiles/
    1899 x 497 - 145K
    1899 x 497 - 150K
    How much space does C: have? Assuming there is a reasonable amount, go to
    and manually remove the
    file, then start Install manger and try installing the application again..
    edited June 2024
    There was no such file. The only file I found was on another disk space. I moved it to another folder. But still no change. Looks like in the second screenshot.
    Edit: #1 - I did now put the "old file" into this folder. This time the log looked like this:
    2024-06-02 20:40:19.255 [INFO] :: Download Successful: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 20:40:19.264 [VERBOSE] :: Saving Adjacent Package Supplement: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 20:40:19.265 [INFO] :: Installing: 13176-2 : DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 20:40:22.308 [WARNING] :: QProcess: Destroyed while process is still running.
    2024-06-02 20:40:23.815 [INFO] :: Install Successful: DAZ Studio 4.22 (Win 64-bit)
    2024-06-02 20:40:23.869 [VERBOSE] :: Removed Package: IM00013176-02_DAZStudio422Win64bit.zip
    2024-06-02 20:40:23.870 [VERBOSE] :: Removed Adjacent Package Supplement: IM00013176-02_DAZStudio422Win64bit.dsx
    2024-06-02 20:40:23.879 [INFO] :: Install Queue Finished: 0 min 4.6 sec
    2024-06-02 20:41:35.592 [VERBOSE] :: Requesting keep-alive...
    2024-06-02 20:41:36.964 [VERBOSE] :: Keep-alive successful
    2024-06-02 20:41:36.964 [VERBOSE] :: Requesting current notification data...
    2024-06-02 20:41:36.965 [VERBOSE] :: Requesting default notification data...
    2024-06-02 20:41:37.528 [VERBOSE] :: Local cache contains default notification data
    2024-06-02 20:41:37.593 [VERBOSE] :: Local cache contains current notification data
    Edit: #2 - Now I took an old (4.12) Version, I saved back in the day external. It seems that the main Daz Studio had a lot of missing files, so it could not start or even update... Don't know for sure. I put the old version into the main directory. The program worked. I took out the manifest file and started Dim agin. Now the popup came up and it installed itself properly with desktop icon and so on. It works now.
    So I gues it's not a bad Idea to have a stable Program somewere else.
    Post edited by gniiial on
