render and engine issues
greetz members...
1st of all im using daz 4.8 pro...
below is the result of render with my pc using 3delight engine.. the setup is simple, only 1 distant light with deep shadow map enabled, plus 1 primitive plane and V4 sets. as u can see bad noises around the figures ,also wierd lines on the darken floor when infact its just a scaled white color primitive plane without any materials at all....
in addition to my problem, i cant find the iray engine in render settings tab, im not sure myself but isnt it supposed to be builtin tools in 4.8 pro??
Post edited by Anymatter on
The 3DL problems are mostly, if not completely, related to Deep Shadow Maps. Don't use them. There's no advantage any longer and they are riddled with deep seated problems that are not ever going to be fixed.
For Iray...you aren't running the 32 bit version of Studio, are you? If so, Iray is 64 bit only.
ok, but i dont think i have such issue with the old version , even if i had, the result not as intense as the image shown above.
hm,im on 32 bit version,no wonder. understood.
mcj thx!
