Designate Camera for Thumbnail Mastery?
avmorganavmorgan Posts: 219
I've had this for a while, but only got around to using it now. My first attempt produced off-center .png's even though the camera in the scene was aligned correctly. Does that mean the camera is ignored or something? I did not see cameras referenced in the documentation. I got the same result when I tried again, so I'd like to get this set up correctly before trying again.
  • HavosHavos Posts: 5,601
    The camera has to be in the scene you select in the Thumbnail mastery popup, and I think the camera has to be called just "Camera". The figure that poses are set for has to be called DSThumbnailFocus. I have had this working for different cameras as I use a different scene file for standing poses to one for sitting poses. The latter involves the camera being slightly more zoomed in and pointing more down.
