Point and Shoot for Iray
Dkgoose
in The Commons
I own the bundle but I can't figure out some of the lights, what's the difference between the red and yellow icons where it says light? Some just give an error that an item needs to be selected othets done appear to do anything, should I redownload and try installing again or am I missing something. The first point and shoot light sets are the only ones that seem to actually load lights in the scene, the rest do not so I'm confused.
Ok, I hope I understood the question right
For the '2 PaS2 Light Setups', you first need to load the 'Point and Shoot 2 Iray (w Helpers)' or 'Point and Shoot 2 Iray' set; the light setups changes the light positons in the set
Idem for the '3 PaS3.......' sets
the '2 PaS2-3 2pt Light Setups' can be used on both the sets
(grrrr.. uploading image is troublesome again.....)
Awesome thanks, someone I blindedly missed those, I'm assuming the regular set needs those loaded first as well thank you :)
