DIM suddenly stopped working [Resolved]
WonderlandWonderland Posts: 7,137
edited May 2024 in The Commons
All of a sudden DIM  won't download anything and I get a red "retry" on every item and then the app crashes. I have several TB of extra space so it's not that. I uninstalled it and reinstalled several times with the same result. What can be done?
It says Exception Reason: DAZ3DIM.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZ3DIM1\QtCore4.dll" at 0033:000000005E2A3A76, QIODevice::isOpen()+6 byte(s)
Registers: RAX=0000000000000000  RBX=000000001401EDD0
RCX=0000000019FAFD88  RDX=0000000000000000
RSI=0000000019FAFD80  RDI=00000000FFFFFFFF
FLG=00010246          RBP=000000000BABAFE0
RSP=000000000BABAED8  RIP=000000005E2A3A76
CS=0033  DS=002B  SS=002B  ES=002B  FS=0053  GS=002B
Full Zip attached
Post edited by Wonderland on
  • Richard HaseltineRichard Haseltine Posts: 111,491
    Try renaming your downloads folder on disc and see if DIM will open then (obviously it will then not see anything downloaded, this is a test not a solution).
    OK, sorry, I'm an idiot. Even though I have tons of room on my install drive, the other external drive with downloads was full. I switched it to download to another hard drive and it seems to be working so far. Thanks.
