Vue, Plant Factory now free
124
  • takezo_3001takezo_3001 Posts: 2,034
    richardandtracy said:
    Agreed. It's incredibly generous. Could have been killed with no release to the world. Has happened with many programs.
    I'm also pleased to have a modern program that replaces the very early and somewhat geriatric looking 'Plant Studio', which was used to create many early poser plant freebies.
    Regards,
    Richard
    On the one hand I'm ecstatic, yet on the other, it's quite a sad turn of events as they were an industry-standard when it came to environmental generation, as the prog was used in avatar!
  • N-RArtsN-RArts Posts: 1,606
    Thank you for sharing. I'll check it out the next time I'm on my rendering PC yes
  • richardandtracyrichardandtracy Posts: 7,368
    Been taking some of the plant factory Acacia trees into DS via obj format. Having made the leaf and smaller branch billboards DS compatible by creating trans-maps, and tweaking the materials for the first one and saved a material setting, the second randomised import shape took but a few seconds to turn into a DS tree. Will have to see if the mesh is the same and if a morphing tree can be created. Fun.
  • kyoto kidkyoto kid Posts: 42,066
    ...the entire package for Windows is something like 18 GB.  Moved it to a high capacity flash drive for now as I have a small Boot Drive.
    I also have a small boot drive, and put everything like this on my D drive, which is a pair of RAID mirror 3 Tb drives - so if one fails, hopefully the other is an intact copy.
  • ElorElor Posts: 3,463
    Does someone know how to open a .vob file in Vue 2023 ?
    I tried to open the file from this freebie ( https://www.renderosity.com/freestuff/items/79969/fly-fishing-set-for-vue ) with Vue 2023 (on my Mac if it's a relevant information) but wasn't able to.
  • Bunyip02Bunyip02 Posts: 9,288
    edited May 2024
    File - Import Object
    1919 x 1040 - 277K
    Post edited by Bunyip02 on
  • VilianVilian Posts: 293
    edited May 2024
    Sad to see the app die, remember it from my early Poser days - must've been back in 2004? Glad to grab it for free tho, and Plant Factory sounds very useful. Thanks for the heads-up!
    (edited for typos, as always)
    Post edited by Vilian on
  • NathNath Posts: 2,987
    In Vue: import object (on Windows). Tested it with some of my old content, but it may not work for everything.
  • tsroemitsroemi Posts: 3,527
    glaseye said:
    It's been quite a while since I've last used Vue for any substantial rendering/scene setup; so it's back to basics and relearn everyting. And I think I heard my CPU screaming when rendering this one. I think it has gotten so used to having the GPU do all the hard work that is has forgotten what it means to do the heavy lifting.....wink
    Cool pic, why are you rendering with CPU though? The FAQ say Vue works with GPUs, at least they recommend having one.
  • glaseyeglaseye Posts: 1,312
    It has it's limitations. For the 'native' vue render engine, anti-aliasing has GPU-support. However, the cycles render engine, which will benefit greatly from the GPU, doesn't handle infinite planes - like with this seascape - very well (at least it gave me trouble on my system...)
    Thank you !
    I found my problem: I needed to open a new scene, otherwise, the menus were not visible blush
  • RAMWolffRAMWolff Posts: 10,368
    It was suggested to me to get all the offerings.  For those interesrted in knowing how much every one of the dowloads adds up too it's 38.5 Gigs total!
  • FirstBastionFirstBastion Posts: 8,050
    This is a render site,  lets see some Vue magic.
    I see, thanks for elaborating!
  • DiscipleDisciple Posts: 186
    Copious thank-yous for this surprising news.
    The last Vue I touched was 6 X-Treme.  I fell in love with its nodes, good for surfaces, sculpting volumes, scattering instances.  I'd hang out in the forums watching for posts asking, "How would you create such-and-such effect?" and tackle them for fun.  Even submitted how-tos for looping seamless cloud motion and merging camera-matched images from Vue and Poser.  Eager to see what the new versions and a GPU can do.
    What were the subscription rates?  I quit paying attention during that era.  Thanks.
    Hallelujah!
    Disciple
    edited May 2024
    Sorry, can't do that. How about a little something in DS with a common primrose from Plant Factory? And a pot & some soil (modelled in SolidWorks, textured via texturelib.com). Image should be called 'My Garden', but I failed with my naming convention.
    As an aside, I used to have a silk primrose in a plastic pot on the parcel shelf in the back of my first car. Looked pretty much like that pot, and was about the biggest garden I could manage at the time.
    Regards,
    Richard
    800 x 800 - 935K
    Post edited by richardandtracy on
    ...now those older high core and thread count Xeons and Ryzerns would come in handy.
  • HavosHavos Posts: 5,614
    edited May 2024
    I have managed to export a number of the props from Vue so they can be used in Daz Studio. It was easier than I expected, I just loaded an object and then exported it.
    These are mostly building props from the main Vue app, not plant props from the plant factory application.
    Whilst some props export fine, a lot have messed up UVs on export. The props look fine inside Vue itself, so I am not sure why they can not be exported properly. Does Vue have some propriety UV system that is difficult to export? Is there some export options I need to select in order to export the props so that their UVs will work in other apps? I tried obj, dae and FBX formats, but in all cases the UVs of some props are messed up.
    There is a gothic cathedral I would particular like to export. I have some Catherdral interiors, but no exteriors like this model.
    Here are some examples of props I have successfully exported out of Vue and rendered in Daz Studio. Some rework of the shaders was done, but on the whole the textures are those exported out of Vue. I think some of the props are sold in the DAZ store here.
    1920 x 1080 - 506K
    1024 x 1024 - 148K
    1920 x 1080 - 189K
    1920 x 1080 - 273K
    1920 x 1080 - 280K
    Post edited by Havos on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,472
    it has Ptex but so apparently does D|S
  • Canary3dCanary3d Posts: 2,033
    edited May 2024
    A few of Stonemason's older sets include a Vue component - you can find the ones you own in DIM by searching for "vue" since it's in the name of those installs (make sure your filters in the Advanced settings include Vue, though, or they might be hidden.) Of the Stonemason sets I own from back then, there are vue files for Tin Pan Alley, City Courtyard, Greeble City Blocks, Skydeck, and The Streets of Asia. So if you own any of those, you can install the Vue files into your Vue library and they'll load up ready to render. This is a straight-out-of-the box render of The Streets of Asia with the default sun position.  I imagine I can get more realism by adding some maps to additional - this was meant for Vue 4, I think, or maybe even Vue 3 - so it's just diffuse & bump maps with a global highlight setting.
    800 x 533 - 74K
    Post edited by Canary3d on
  • Ryuu@AMcCFRyuu@AMcCF Posts: 779
    That's both great news and kind of sad.
    On the plus side, I can finally make use of a lot of ancient Vue products I have but had become defunct when my early Vue application became corrupted and I could no longer use it. I couldn't even reinstall it as that app version was no longer supported.
    On the downside, no more new stuff.
    edited May 2024
    Dear DAZ3D,
    The product filters on your shop pages list a fair number of software titles. Vue should be one of them.  Cornucopia3D's absence leaves a vacuum.  I invite you to consider entering it.  Thanks for reading.
    [edit=1]Now I see a Categories block amongst the product filters, answering one of my wishes for some time. yes Thank you.[/edit]
    Hallelujah!
    Disciple
    Post edited by Disciple on
  • procyon98procyon98 Posts: 0
    A low resolution version of one of my more popular Vue pieces.  I have some more.  One with a hanging Poser Skeleton.  But that one is at night so the lighting is very dark, I don't like showing it.
    320 x 213 - 58K
    Does anyone know any good reviews/introductions for VUE? (No YouTube)
    edited May 2024
    PerttiA ignore this
    Everyone else,
    I fell asleep watching this and a snore woke me up with a start devil
    (big reason I don't watch video tutorials either wink)
    one of the AI tutorial posting YouTubers I sometimes watch is uploading Vue tutorials now cheeky
    he used to do Vue tutorials before AI
    edited May 2024
    After having a look at the manual, I get the impression that VUE is like Bryce on steroids, am I correct or is there more to it?
    Post edited by PerttiA on
    yes definitely
    but Carrara is faster  cheeky
  • davesodaveso Posts: 7,918
    way beyond Bryce. A lot of steroids.
    I used to think Vue was pretty easy to use, but it sure seems a lot more complicated than what I remember. Plant Factory is a different beast as well. not easy
