Adding to Cart…
Hello! Any updates? I can't afford Maya so I can't use your amazing plugin but it is exactly what I need to do what I want to do for a game in Unreal. To hear you are making one for Daz without Maya sounds like a dream.
Incredible work, by the way. It is making me hopeful for using Daz characters in Unreal. I didn't know the JCM problem and now I don't even know how to make a game with how poorly Daz characters move, and not having any real tutorials on how to do what you did here it seems this is the best solution available.
I have this warnings after running DTL script:---------------------------
DTL Exporter
522 morphs exported for Genesis 8 Female with warning(s):
Warning: pCTRLFlexBiceps_twist_L_dq2lb was specified for morph export but was not found
Warning: pCTRLFlexBiceps_twist_R_dq2lb was specified for morph export but was not found
Warning: pJCMAbdomen2Fwd_40_dq2lb was specified for morph export but was not found
Warning: pJCMAbdomen2Side_24_L_dq2lb was specified for morph export but was not found
Warning: pJCMAbdomen2Side_24_R_dq2lb was specified for morph export but was not found
Warning: pJCMAbdomenFwd_35_dq2lb was specified for morph export but was not found
Warning: pJCMBigToeDown_45_L_dq2lb was specified for morph export but was not found
Warning: pJCMBigToeDown_45_R_dq2lb was specified for morph export but was not found
Warning: pJCMChestFwd_35_dq2lb was specified for morph export but was not found
Warning: pJCMChestSide_20_L_dq2lb was specified for morph export but was not found
Warning: pJCMChestSide_20_R_dq2lb was specified for morph export but was not found
Warning: pJCMCollarTwist_n30_L_dq2lb was specified for morph export but was not found
Warning: pJCMCollarTwist_n30_R_dq2lb was specified for morph export but was not found
Warning: pJCMCollarTwist_p30_L_dq2lb was specified for morph export but was not found
Warning: pJCMCollarTwist_p30_R_dq2lb was specified for morph export but was not found It's matter on clean Genesis 8 character. Can anybody suggest me please.
Can i get involved into beta test?
