The Strange Affair of the Distant Zoom Framing Operation!
acanthisacanthis Posts: 604
edited January 2016 in Daz Studio Discussion
Post edited by acanthis on
  • MelanieLMelanieL Posts: 7,754
    Oh the number of times I've done this recently...!
    Actually the framing box does work with Surface Selector as long as you have a surface selected - I use that a lot to zoom into a specific part of an outfit or building. The problem is when you click away from the selected bit.
  • acanthisacanthis Posts: 604
    edited January 2016
  • Richard HaseltineRichard Haseltine Posts: 108,591
    Why would you frame nothing? If you wanted to frame a whole scene you'd then have to select every item.
  • MattymanxMattymanx Posts: 6,997
    If nothing is selected in the scene tab while the node selector is used and you click the frame button, then the entire scene is framed.
    Yes, that's what I was referring to.
