EM3D Keera Stylized HD for Genesis 9 Clothing question
in The Commons
Quick question. What outfits are used in the promotional page for this new character? Specifically the white dress with red cape, and gold boots. And in the red with full white undergarment with red boots. Any help is appreciated. Also many thanks for the help in advance.
Links might help
I was curious about the same thing for both the Keera Stylized set (https://www.daz3d.com/em3d-keera-stylized-hd-for-genesis-9) and for the Kohl Stylized set (https://www.daz3d.com/em3d-kohl-stylized-hd-for-genesis-9).
Any help would be apprciated.
I just wanted to let you know I saw your question and I will be back with some links for you ;-)
The Red outfit is from this set- with most made invisible and the white body suit underneath is just a geoshell with a white shader.
https://www.daz3d.com/zk-higia-sci-fi-outfit
The White Dress and Gold boots are from this set- I just removed the diffuse textures set the color to white and used a Gold shader for the boots and everything else. I custom added the flourish on the front though.
https://www.daz3d.com/x-fashion-olympian-warrior-outfit-for-genesis-9
This is the Red Cape- just removed the diffuse texure and used a Red Velvet shader.
https://www.daz3d.com/dforce-ssc-knight-cloak-for-genesis-9
Many thanks everyone! Especially Jeni!
Depending on your geometry editor and perhaps mesh grabber or other skills with say Hexagon or Blender, you might be able to attach the 'flourish' from this outfit to the Olympian Warrior outfit...
https://sharecg.com/v/94807/gallery/11/Poser/She-Ra-for-Elizabeth-2
I haven't tried it yet, but I've worked with this outfit before. Note that the outfit is designed for Elizabeth 2 (Poser figure), and last time I checked there weren't decent autofit options, but that may have changed, it's been a while since I messed with the above outfit.
Might be more trouble than it's worth, just pointing out this option.
Also, thanks Jeni for sharing the links!
Also this is the castle I used for the promo renders below
https://www.daz3d.com/the-skull-castle
