Oops
rcosu19rcosu19 Posts: 31
I have somehow made it so everything is invisible, and I can't seem to find the setting to change it back.  =/   Could someone point me in the right direction?
    Check the scene tab to make sure you haven't 'closed the eye' next to the figure...
    Or, if that isn't the case, look up and to the left of what you have almost posted, in the upper right corner of your image.  There should be a little 'ball' with a down arrow...click that and make sure it's set to texture shaded.
  • rcosu19rcosu19 Posts: 31
    The second thing got it, thanks!  I was about to go nuts!
