Are you looking for prompts ?
Bunyip02
Have collected a few prompts, thought I would share them.
Open the txt file in Notepad.
Enjoy !
Edit - 100 Prompts - Fantasy woman added
Edit - 100 image prompts - Teddy Bear added
Edit - 100 image prompts - toon animals added
Edit - Prompts - Body Types added from later post
Edit - Prompts - Body Types Skinny Fat etc added from later post
Post edited by Bunyip02 on
Thanks, will try. :-)
You are welcome.
Some of the prompts are collected from various sources, while the rest are AI Chat generated.
The AI Chat ones do get repetitive, and also when asked for 100 prompts the AI ran out of ideas before reaching the 100 in some cases.
I was hoping for some to create various body shaped. So far I seem to use common words/phrases and only have it work a fraction of the time. i.e. If I try to create a chubby, voluptuous, shapely character, they tend to be created a majority of the time as very ideal and normal. Once in a while I might get a short streak where they render as intended, but it is quite iratic.
Anyone have any prompts that worked successfully?
For me, female dwarf worked fairly well. You'll need to specify the environment if you don't want a fantasy setting.
Have not tried these yet, but might be worth a look. Open txt files in Notepad
EDIT - Tried some random types, been getting good results so far.
Digital painting of a plump, fat individual with round cheeks and a jovial expression
Artwork depicting a curvy model with a pear-shaped body and full hips
Drawing of a stocky man with a powerful build and sturdy frame
Picture of a plus-size model with confidence and body positivity
Digital rendering of a petite figure with a slight frame and delicate features
Illustration of a stocky lumberjack with a burly build and rugged appearance
Concept art of a slender elf with ethereal beauty and delicate features
Visual representation of a chubby baker with a love for sweets and pastries
Visual representation of a tiefling bard with mesmerizing music and dark charisma
Concept art of a half-orc paladin with a blend of strength and divine magic
Picture of a gnome wizard with magical gadgets and arcane knowledge
Digital rendering of a dragonborn sorcerer with draconic bloodline and arcane spells
Great examples, @Bunyip02, and thank you for the prompts.
Thanks ! You are welcome, thought I would give something back to the community for all the times I have been helped out. There are some Toon prompts in the first txt file.
Thank you very much for your prompts, Bunyip02! Some are a bit difficult for the program to present (e.g. 'Virtual reality becomes indistinguishable from real life.'), but you give us a wealth of inspiration. Today I shortened your prompt 'A swamp monster lurking in the murky waters, waiting to drag unsuspecting travelers under' to 'A swamp monster, waiting to drag unsuspecting travelers under' and received great pictures.
Looking good !
Aswesome thanks you for these!
used :
in my prompt:
Sea Conch{zebra print} held by Muscle Woman{curvy pin-up model with retro charm and allure} classic pose, beachside
Use and modify the prompts to your hearts content !!!
Any clue as to whether to be using {} or () for adding weights in Daz AI? Or does it even make a difference. Daz AI has no clue what a Radarscope is btw, so would be cool to be able to use a start image.
