Spinning and spinning
CerragCerrag Posts: 255
edited April 2024 in Daz AI Studio
That's all that's going on for most of Daz AI Studio today.  Yesterday it worked Great but today, ... not so much.  It's not generating most of the images, 2 out of 8 at most and I've tried two different browsers, changed my settings in Daz AI but nothing is helping.  I just signed up for a PAID subscription yesterday too so I'm kind of *really disappointed.  Any advice for a workaround or better yet, DAZ, ... can you please see what's going on?  Cause everything on my end yesterday was Perfecto!
It's also not saving my Generation History.   What an absolute downer.
Post edited by Cerrag on
  • creed2003creed2003 Posts: 69
    If you try and render something that is against the TOS this is what happens. Try rewording your prompt and see if that helps.
  • CerragCerrag Posts: 255
    Thanks and I've been just using varations of the same prompt, over and over and nothing inappropriate that should trip up the TOS.  But I appreciate your tip and will try it again anyway.  It's just that I did that same thing yesterday, exactly as I am today, and no problems at all so it doesn't make sense to me.  indecision
  • Bunyip02Bunyip02 Posts: 9,226
    Had the same problem before, and it's not the prompts being against the TOS. Had one day when I was getting all 8 generations just spinning, following day with same prompt they generated out in less than a minute.
    Looks like DAZ might need to upgrade the Hamster !
  • AnitaLeeAnitaLee Posts: 51
    I fins that if I try to get too specific with my propts it just spins and spins, which is unfortunate.  I had thought of upgrading but does not make me feel like it would do any better.  It just can not handle really well developed propts.  Nothing that would be against TOS
  • CdpiersonCdpierson Posts: 74
    You're not the only one this is happening to today.  For awhile this afternoon, I could get one image generated, then have to reload the page to do another.  Eventually, it just stopped doing anything except spinning.  I decided to wait and see if it's improved by tomorrow.
    edited April 2024
    Yep - Hamster needs upgrading .....
    1054 x 530 - 313K
    Post edited by Bunyip02 on
    Its doing the same for me today as well so it's not a TOS issue
    Out of 8 images attempting to generate, I am averaging 3 images generated and 5 swirlies. Come on DAZ, fix-up that hamster !!!
  • linvanchenelinvanchene Posts: 1,386
    edited April 2024
    It is not always a TOS issue.
    Clearly, at the moment the server seem to struggle for some reason.
    This morning there was not a single series where all 8 images finished generating.
    I retested with prompts that used to work before:
    If you see 8 slots not generating an image you very likely used a word that is flagged for some reason.
    Censorship example
    safe version
    This is the safe version of the prompt that should not trigger any issues when servers are working:
    portrait of a man(buzzcut,),  relaxing on a deck chair, aloha shirt, long shorts, beach, palms, golden hour, depth of field,
    edited: Retested after servers were functional again:
    works  now as expected...
    Flagged prompts - topless
    The prompt asks for a topless man on the beach:
    portrait of a man(buzzcut,),  relaxing on a deck chair, topless, long shorts, beach, palms, golden hour, depth of field,
    Without any doubt the word "topless" triggers censorship.
    The image generator does not make a difference based on gender and situation here and does not display any generated images.
    The underlying issues
    • Without a proper log and error message system the users will not be able to tell why exactly their prompt failed.
    • Some prompts will very likely trigger censorship even though the users may not even be aware what they did wrong.
    945 x 549 - 82K
    955 x 566 - 78K
    936 x 517 - 84K
    932 x 610 - 92K
    935 x 544 - 38K
    Post edited by linvanchene on
  • 31415926543141592654 Posts: 975
    I concur,  I am only trying 1 image at a time as I am only practicing with how to make prompts ... and that 1 image gets stuck spinning ... this has been happening for 24 hours ... and I am also a paid member.
    Remember, this is a Daz Beta ... we should expect some problems as it is developed.
  • FirstBastionFirstBastion Posts: 8,047
    edited April 2024
    On occassion, when the constant spinning happens, I just start a new session, and type in the single word -  pizza.
    There maybe many rules under to hood that we do not see.  A user directed message would certainly be a welcomed addition to this process.
    But veggie pizza,  had it swirling again.  Perhaps there are other issues at play this morning.
    269 x 729 - 55K
  • RexRedRexRed Posts: 1,493
    edited April 2024
    Same here, spinning and spinning. When you refresh the page I think it leaves a slot in the server still "occupied" and "busy". Over time this might overwhelm the system.
    When you refresh the page the inquiry should reset on the server. A system reboot might be in order.
    Post edited by RexRed on
    It seems to have cleared up for me.  I don't want to say too much for fear I might jinx it.
  • Richard HaseltineRichard Haseltine Posts: 107,860
    The servers were kicked, or something along those lines.
     You shouldn't use technical jargon with people over 70, Richard.  It just confuses us.
    Poor Hamsters, running on empty - then getting booted for their efforts .....
