• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Cinema 4D Discussion
Daz hair texture not working [help]
guicosta051guicosta051 Posts: 0
April 2024 edited April 2024 in Cinema 4D Discussion
Hello, I'm trying to send Daz's character's hair to Cinema 4d, but it only sends the lower part, does anyone know how to solve it?
I'm using the plugin that Daz made
Community Verified icon
Post edited by Richard Haseltine on April 2024
  • GordigGordig Posts: 10,642
    April 2024
    Is that Emile hair? If so, that's strand-based, so what you'll want to do is configure it in C4D as hair.
    1. Set line tesselation on the hair to 0 in viewport, and I usually do 1 for render, but I don't remember if that's important.
    2. Export as OBJ. For C4D, scale should be set to 100%
    3. Merge that OBJ with your bridged character
    4. Delete everything except the spline object(s). Depending on how the hair is set up, there might be multiple objects or just one. I generally combine everything into a single spline object unless there's a compelling reason to keep parts separate (shaved sides, ponytails etc.)
    5. Simulate -> Hair Edit -> Convert from Spline (forgive me if some of the terminology isn't exactly correct, I'm not at a computer). You can delete the original spline object now if you wish
    6. Set the haircap as the guide base. If this causes the guides to jump around, set Hair Mode to Roots and use the Hair Move tool to nudge them back into place
    7. Simulate -> Hair Edit -> Set Roots. I never really mess with these settings, I just hit apply
    The hair is now C4D hair, it's attached to your character, and it will render. You'll need to add a hair material to set thickness and whatnot, change the hair settings for density and number of hairs, maybe add a density map to the hairs and/or guides...there's a little bit of a process to get the hair to look exactly as it did in DS, and that will vary from hair to hair.
    April 2024
    As an additional note, when exporting SBH from DS, you might want to play around with the Simulate settings under parameters. DS SBH consists of PS hairs and PR hairs, and generally PR hairs will be the full density. If that's more guides than you want, you can try disabling PR hairs and export only the PS hairs, which will usually be much less dense, sometimes only a dozen or so base guides. I think there has been a couple times where even PS hairs were denser than I wanted, so I disabled those as well. If you do this often enough, you'll start to get a feeling for what the right settings are for a given hair.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
