So! I reinstalled Daz and..
zoophilian
I had to uninstall Daz via the installer and set up everything to install to my second hard drive (From drive C, to drive D) Made sure everything installed to D but now, when i start up Daz I have no smart library, Or rather everythign is there but with an exclamation point on it and none of the models load O.o
Reinstalled about four times now and nothign >_> No matter what i do it still wont read that i have installed the librarys to a new spot.
It won't...no matter how many times you reinstall. The locations will need to be manually changed within Studio itself. And then the database will need to be rebuilt. It doesn't wipe/clear the content locations, because 99% people will be reinstalling to the same location...not moving the content, too.
You need to bring up the Content Directory Manager and manually map the new locations.
Edit > Preferences (F2) > Content Library > Content Director Manager.
I did, I directed Daz librarys to the new directorys and same issue
Did you have custom categories?
If you did, it may be too late for them...but you need to do database maintenance now.
