Render starts then IRAY rend error and ends, Render is clearly not done all samples.
HyeVltg3HyeVltg3 Posts: 88
I lastly assumed it was old drivers, was on 546, but I just updated to the latest Nvidea Drivers (using DDU) as of today but The issue remains. So I am going to come here and ask, maybe there is something I can try because I am seriously depressed that I have made 0 progress all weekend.
I have 2 G8 characters in the scene, interior scene and I thought it initially was because the second character is using the Fantasy Skins 8.1 because it felt like all these issue started after introducing the fantasy skins
G81F and G81M, the Male is using the fantasy skins, I rendered a few PNGs before this where the G81M was not skin colored but now that the G8M is, I am having an issue like this every 2nd or 3rd render, need to restart and reload the scene to be able to render again.
https://www.daz3d.com/fantasy-skins-for-genesis-81-males
Scene uses about 10,329MB according to HWInfo, I grabbed the number after the Rendering starts as I know it inflates (went from 3GB to 11GB)
DAZ 3D 4.22.0.16
AMD 3950X
64GB RAM
RTX 3090
Windows 11 64-bit
(wish there was a Spoiler/drop-down tag, sorry for the wall of text)
2024-04-09 19:52:44.048 Iray [INFO] - IMAGE:IO ::   1.0   IMAGE  io   info : Loading image "C:\Program Files\DAZ 3D\DAZStudio4\shaders\iray\resources\DTHDR-RuinsB-500.hdr", no selector, pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2024-04-09 19:52:44.050 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   progr: Traversing scene.
2024-04-09 19:52:48.907 Iray [INFO] - TRAV:DATABASE ::   1.0   TRAV   db   info : Traversing scene took 4.857 s.
2024-04-09 19:52:48.943 Iray [INFO] - POST:RENDER ::   1.0   POST   rend info : Postprocessing denoiser is enabled
2024-04-09 19:52:48.947 Iray (Scene Update) : Updating LPE labels
2024-04-09 19:52:48.948 Iray (Scene Update) : Updating geometry contexts
2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry contexts.
2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
2024-04-09 19:52:48.948 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
2024-04-09 19:52:48.949 Iray (Scene Update) : Retrieving geometry
2024-04-09 19:52:48.949 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 triangle object with 35 M triangles, 1 instance) took 2.403 s
2024-04-09 19:52:51.352 Iray (Scene Update) : Updating motion transform data
2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating motion transforms.
2024-04-09 19:52:51.352 Iray (Scene Update) : Updating section objects
2024-04-09 19:52:51.352 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating section objects.
2024-04-09 19:52:51.353 Iray (Scene Update) : Updating materials
2024-04-09 19:52:51.353 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
2024-04-09 19:52:51.682 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 481 textures, 0 lambdas (0 unique)
2024-04-09 19:52:51.682 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Emitter geometry import (6 light sources with 1089 triangles, 1 instance) took 0.000 s
2024-04-09 19:52:51.683 Iray (Scene Update) : Updating environment
2024-04-09 19:52:51.683 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment.
2024-04-09 19:52:51.691 Iray (Scene Update) : Updating code
2024-04-09 19:52:51.691 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled material code.
2024-04-09 19:52:51.691 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled environment code.
2024-04-09 19:52:51.691 Iray (Scene Update) : Updating textures
2024-04-09 19:52:51.692 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating material textures.
2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating environment textures.
2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating BSDFs.
2024-04-09 19:52:51.699 Iray (Scene Update) : Updating volumes
2024-04-09 19:52:51.699 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating volumes.
2024-04-09 19:52:51.699 Iray (Scene Update) : Updating lens data
2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lens.
2024-04-09 19:52:51.700 Iray (Scene Update) : Updating lights
2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
2024-04-09 19:52:51.700 Iray (Scene Update) : Updating instance topology
2024-04-09 19:52:51.700 Iray (Scene Update) : Updating flags
2024-04-09 19:52:51.700 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
2024-04-09 19:52:51.700 Iray (Scene Update) : Updating backplate
2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate.
2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating compiled backplate code.
2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating backplate textures.
2024-04-09 19:52:51.701 Iray (Scene Update) : Updating decals
2024-04-09 19:52:51.701 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
2024-04-09 19:52:51.720 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using iray core convergence estimate.
2024-04-09 19:52:51.722 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using batch scheduling, caustic sampler enabled
2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing local rendering.
2024-04-09 19:52:51.733 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Caustic sampler implies guided sampling.
2024-04-09 19:52:51.739 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using OptiX version 7.5.0
2024-04-09 19:52:51.744 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Initializing OptiX for CUDA device 0
2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : 	CUDA device 0 (NVIDIA GeForce RTX 3090)
2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2024-04-09 19:53:02.702 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): Processing scene...
2024-04-09 19:53:02.703 Iray (Scene Access) : Retrieving geometry
2024-04-09 19:53:02.703 Iray (Scene Access) : Retrieving device geometry
2024-04-09 19:53:03.140 Iray (Scene Access) : Retrieving volumes
2024-04-09 19:53:03.141 Iray (Scene Access) : Retrieving textures
2024-04-09 19:53:05.733 Iray (Scene Access) : Retrieving device textures
2024-04-09 19:53:06.143 Iray (Scene Access) : Retrieving flags
2024-04-09 19:53:06.144 Iray (Scene Access) : Retrieving device flags
2024-04-09 19:53:06.145 Iray (Scene Access) : Retrieving lights
2024-04-09 19:53:06.145 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Importing lights for motion time 0
2024-04-09 19:53:06.145 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Initializing light hierarchy.
2024-04-09 19:53:06.152 Iray [INFO] - IRAY:RENDER ::   1.4   IRAY   rend info : Light hierarchy initialization took 0.006 s
2024-04-09 19:53:06.152 Iray (Scene Access) : Retrieving device lights
2024-04-09 19:53:06.152 Iray (Scene Access) : Retrieving section objects
2024-04-09 19:53:06.153 Iray (Scene Access) : Retrieving device section objects
2024-04-09 19:53:06.153 Iray (Scene Access) : Retrieving materials
2024-04-09 19:53:06.157 Iray (Scene Access) : Compiling custom code
2024-04-09 19:53:06.157 Iray (Scene Access) : Retrieving environment
2024-04-09 19:53:06.160 Iray (Scene Access) : Retrieving device environment
2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving backplate
2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving device backplate
2024-04-09 19:53:06.161 Iray (Scene Access) : Retrieving decals
2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving device decals
2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving motion transform data
2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving device motion transform data
2024-04-09 19:53:06.162 Iray (Scene Access) : Retrieving lens data
2024-04-09 19:53:06.163 Iray (Scene Access) : Retrieving device lens data
2024-04-09 19:53:06.196 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Scene processed in 3.494s
2024-04-09 19:53:06.206 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 102.832 MiB for frame buffer
2024-04-09 19:53:06.211 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 1.969 GiB of work space (2048k active samples in 0.005s)
2024-04-09 19:53:06.211 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Optimizing for cooperative usage (performance could be sacrificed)
2024-04-09 19:53:07.119 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend info : Allocating 1-layer frame buffer
2024-04-09 19:53:07.137 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 73
2024-04-09 19:53:07.184 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00001 iteration after 4.482 s.
2024-04-09 19:53:07.912 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 214
2024-04-09 19:53:07.920 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00002 iterations after 5.219 s.
2024-04-09 19:53:08.806 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 518
2024-04-09 19:53:08.815 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00003 iterations after 6.114 s.
2024-04-09 19:53:09.768 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 874
2024-04-09 19:53:09.777 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00004 iterations after 7.075 s.
2024-04-09 19:53:10.614 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 994
2024-04-09 19:53:10.625 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00005 iterations after 7.923 s.
2024-04-09 19:53:11.689 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1054
2024-04-09 19:53:11.697 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00006 iterations after 8.996 s.
2024-04-09 19:53:12.511 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1104
2024-04-09 19:53:12.542 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00007 iterations after 9.841 s.
2024-04-09 19:53:13.940 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1190
2024-04-09 19:53:13.949 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00008 iterations after 11.247 s.
2024-04-09 19:53:14.695 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1233
2024-04-09 19:53:14.703 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00009 iterations after 12.002 s.
2024-04-09 19:53:15.411 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00010 iterations after 12.709 s.
2024-04-09 19:53:16.236 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 1236
2024-04-09 19:53:16.245 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00011 iterations after 13.543 s.
2024-04-09 19:53:17.606 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00013 iterations after 14.904 s.
2024-04-09 19:53:18.449 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 2287
2024-04-09 19:53:18.459 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00014 iterations after 15.757 s.
2024-04-09 19:53:19.694 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00016 iterations after 16.992 s.
2024-04-09 19:53:20.917 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 3357
2024-04-09 19:53:20.926 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00018 iterations after 18.224 s.
2024-04-09 19:53:22.420 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00021 iterations after 19.717 s.
2024-04-09 19:53:24.062 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 4421
2024-04-09 19:53:24.094 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00023 iterations after 21.392 s.
2024-04-09 19:53:25.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00027 iterations after 23.266 s.
2024-04-09 19:53:27.380 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 5851
2024-04-09 19:53:27.390 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00029 iterations after 24.688 s.
2024-04-09 19:53:30.188 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 37.18% of image converged
2024-04-09 19:53:30.206 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00035 iterations after 27.504 s.
2024-04-09 19:53:31.366 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 6994
2024-04-09 19:53:31.375 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00037 iterations after 28.674 s.
2024-04-09 19:53:33.968 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00042 iterations after 31.266 s.
2024-04-09 19:53:36.172 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 9075
2024-04-09 19:53:36.206 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00047 iterations after 33.504 s.
2024-04-09 19:53:39.013 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00053 iterations after 36.311 s.
2024-04-09 19:53:41.663 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 11367
2024-04-09 19:53:41.697 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00059 iterations after 38.995 s.
2024-04-09 19:53:45.040 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 54.16% of image converged
2024-04-09 19:53:45.040 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00067 iterations after 42.339 s.
2024-04-09 19:53:48.317 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 13478
2024-04-09 19:53:48.350 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00074 iterations after 45.648 s.
2024-04-09 19:53:51.255 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00081 iterations after 48.553 s.
2024-04-09 19:53:54.614 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00089 iterations after 51.913 s.
2024-04-09 19:53:56.216 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 16379
2024-04-09 19:53:56.224 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00092 iterations after 53.522 s.
2024-04-09 19:54:00.537 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend progr: 64.49% of image converged
2024-04-09 19:54:00.555 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00101 iterations after 57.853 s.
2024-04-09 19:54:05.726 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00110 iterations after 63.025 s.
2024-04-09 19:54:07.634 Iray [INFO] - IRAY:RENDER ::   1.2   IRAY   rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): guidance merge/update for: #caches = 20374
2024-04-09 19:54:07.643 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Received update to 00114 iterations after 64.941 s.
2024-04-09 19:54:11.387 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Kernel [15] (LensTraceSr       ) failed after 2.157s
2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while launching CUDA renderer in <internal>:908)
2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.5   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Failed to launch renderer
2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Device failed while rendering
2024-04-09 19:54:11.388 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.2   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3090) is no longer available for rendering.
2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER ::   1.2   IRAY   rend warn : All available GPUs failed.
2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: Fallback to CPU not allowed.
2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while initializing memory buffer)
2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: All workers failed: aborting render
2024-04-09 19:54:11.389 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): [Guidance sync] Failed master device (remaining 0, done 0).
2024-04-09 19:54:11.390 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2024-04-09 19:54:11.391 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2024-04-09 19:54:11.392 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER ::   1.2   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): the launch timed out and was terminated (while de-allocating memory)
2024-04-09 19:54:11.393 [ERROR] Iray :: Internal rendering error.
2024-04-09 19:54:12.439 [INFO] :: Saved image: C:\Users\***\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2024-04-09 19:54:12.451 [INFO] :: Finished Rendering
2024-04-09 19:54:12.560 [INFO] :: Total Rendering Time: 1 minutes 56.55 seconds
Post edited by HyeVltg3 on
    One thing jumps out, "Geometry import (1 triangle object with 35 M triangles, 1 instance)"... What is that?
    DS likes quads better than triangles, and 35 million triangles is insane amount.
    When rendering, do you use Iray in your viewport as well?
  • HyeVltg3HyeVltg3 Posts: 88
    No I use Iray Preview and then change to Smooth Shaded before hitting Render.
    So its the amount of triangles that could be causing it, so it would have to be geometry right? not textures, I was under the impression that it was the textures because the issue comes up as soon as I make visible the G81 with the fantasy skins enabled, the setup process enables a lot of extra options in Surfaces (FX1, FX2 colors).
    The main thing I can think of is that my scene is:
    1. Indian Bedroom 5 (no longer available on Daz Store) does not look that heavy on triangles and quads
    2. G81 female with clothing
    3. G81 male with shorts on only
    4. The bedsheet from https://www.daz3d.com/ultimate-dforce-single-bed
    I have to assume its the bedsheet? its a dForce bedsheet and it has tons of geometry from the looks of Wireframe view.
    I also tried lowering the SubD from 4 to 3 and so far it feels like its crashing less but the problem is still there.
    Just wanted to confirm the take away here is that its the Triangles count that matters (balance of Triangles and Texture size) - Is there an easy way to see the total triangles and some sort of Range I should stick Under, for 23.4GB of VRAM ?
    That is one possible problem, as it seems that Iray preview leaves stuff in VRAM cache for subsequent use just like regular Iray rendering does, but these caches are different with preview being lower quality.
    When rendering, the stuff in the regular Iray cache will be used again, but stuff in preview cache is just wasting additional VRAM.
    One should change to texture or smooth shaded first, save the scene, exit DS, open DS and the scene again without activating Iray preview before rendering.
