[How-to?] Attach/Connect eyelets, laces, knots in DAZ?
Hello,
[[How-to?] Attach/Connect eyelets, laces, knots in DAZ?] Everything is in the title. What is the proper way to connect "parts" like eyelets, laces and knots for clothings and shoes?
If the item is conforming, e.g. shoes, you can just model it in place. It will automatically follow the rest.
If the clothing shall be able to be simulated, eyelets would be attached with rigid follower nodes. Laces and knots, I would usually try to model into the clothing, but if you don't plan to simulate them you can use rigid follower nodes. I tried one to have the eyelet and a lace attached with rigid follower nodes, with the lace as dynamic, but it is sensitiv to too much movement, so probably not a good way.
Ok. I will check that. Thanks.
