Poser Importer trouble
I made Poser import file for DAZ Baryolax Expansion
When I imported at first , the Baryolax Expansion Eel Tail figure was shown.
Then I attached Eel Tail to the Baryolax ,  Eel Tail figure is transparent
Why ?
    Check the Opacity settings...frequently they come in wrong.
  • I checked Opacity , it's  0 .
    When attached  it, what it is happend ?
    It's just one of the material settings that frequently doesn't translate well.  The obj/mtl format is particularly picky and limited in it's naming conventions and if everything isn't 'perfect' materials aren't correctly set up.  And that is not including the fact that there are only limited materials that can be included AND out of that set, not everything between Poser and Studio materials has the same names/functions.
