Transfer Utility creating "webbed" texture?
So this always happens whenever I try to transfer utillity for any clothing that has the arms near the body.
  • Richard HaseltineRichard Haseltine Posts: 109,203
    The Transfer Utility projects weights into the new item based on which body part theya re closest too - in this case some of the sleeves received weight for the Torso bones. You need to fix this with the Node Weightmap Brush tool, painting the arm bone influence into the edgs of the sleeve.
