Genesis 9 does not load in default
Abstract Soul
I have been playing around with morph creation and I think I might have done something wrong since
now everytime I load g9, it loads with morphs applied.
I followed 5 different tutorials on figure reset with no luck
it is not a morph I created since I uninstalled them, but rather something else since all the morphs dialed are from the base proportion folder of genesis 9 essentials in the data folder.
I tried unistalling and reinstalling genesis 9 essentials also with no luck.
any help would be greatly appreciated
these are some of the tutorials I followed
https://www.daz3d.com/forums/discussion/comment/8277756/
For the purpose of figuring out the morph that has it's default value set at non-zero value, select "Show hidden parameters" and zero the figure.
Once you have zeroed the figure, check the "Currently used" list - The problem morph should have it's value "0" shown in white.
Thank you so much PerttiA, found it! turns out it wasnt one of my morphs, it was Luciano by Matari 3D the one causing problems
