Genesis 9 does not load in default
I have been playing around with morph creation and I think I might have done something wrong since
now everytime I load g9, it loads with morphs applied.
I followed 5 different tutorials on figure reset with no luck
it is not a morph I created since I uninstalled them, but rather something else since all the morphs dialed are from the base proportion folder of genesis 9 essentials in the data folder.
I tried unistalling and reinstalling genesis 9 essentials also with no luck.
any help would be greatly appreciated
these are some of the tutorials I followed
https://www.dropbox.com/scl/fi/uki9mjlvvjmb0svljk1gw/Fix-Base-Characters.pdf?rlkey=uh336z0x8zknddr6rvf0r8vmg&dl=0
https://www.daz3d.com/forums/discussion/comment/8277756/
    For the purpose of figuring out the morph that has it's default value set at non-zero value, select "Show hidden parameters" and zero the figure.
    Once you have zeroed the figure, check the "Currently used" list - The problem morph should have it's value "0" shown in white.
  • Abstract SoulAbstract Soul Posts: 169
    edited April 2024
    Thank you so much PerttiA, found it! turns out it wasnt one of my morphs, it was Luciano by Matari 3D the one causing problems
