Save Draft not working
Taoz
in The Commons
Just wrote a long reply in a thread, then I accidently hit a keyboard shorcut in Chrome (god, how these can drive me mad sometimes) which closed the tab. So I returned to the thread, believing my comments was saved by auto save draft, but it was gone. I even clicked Save Draft myself a few times when I wrote it just in case, but apparently that doesn't work either.
Yeah ... been there. To avoid that, I compose my posts and reply to posts in Word and then copy-and-paste the text into the comment box. :(
As far as I can tell, it only works in the quick reply box at the bottom of the topic page. If you've gone to a separate post page, the drafts then don't work, even if you click the button.
I use to do that too, or copy regularly to ClipCache when I know there's no recovery option, but it used to work here at DAZ. Couldn't even cancel a post unless there was a dot or whatever in the box which it then would save.
OK, but then they should remove that misleading button at least.
And then there's the lack of a delete double post button...
If you have started to write, and don't want to post after it has been saved manually or auto-saved, refresh the page without posting and click the cogs in the upper right corner. You should now have a "My Drafts" entry in the drop-down list. Follow that link, and you will see any drafts of your posts. Click the "x" to delete it.
Posts are doubled, tripled, quadrupled etc. if one is impatient and pushed the "Post comment" button several times, or one refreshes the page after Cloudflare problems.
