Need help please! How I can fix this???!
Hi, I accidentaly clicked on "Make panel undockable" on the "Light tab". Then I try to solve this problem and make this on all tabs (now is like the file attached). How I can put the default tabs? Thanks!!!
  • Ralf1958Ralf1958 Posts: 688
    Just klick and drag the pane (little label in the window on the upper left) back to his original position.
    Or change your layout...even reloading the one you are currently using should reset it.
    Window > Workspace >Select Layout
  • ScavengerScavenger Posts: 2,674
    Reloading the layout to my saved choice is my default "Something is wrong" fix.
  • Richard HaseltineRichard Haseltine Posts: 108,459
    or reload your layout - Window>Workspace>Select layout....
  • Thanks!!!!!!!! It work! :D
