Product does not install
jodhan322jodhan322 Posts: 65
I purchased https://www.daz3d.com/pose-architect-for-genesis-8-females, but installing it has failed several times. I've done it through the Daz install tab, and I've used the Daz Installer. Every time I install it, the image is a trangle with an exclmation mark. And it says error when I try and click on the script. I can't find a way to get this working. Anyone else run into issues like this?
Post edited by jodhan322 on
  • Richard HaseltineRichard Haseltine Posts: 108,735
    edited March 2024
    Please use the store link, https://www.daz3d.com/pose-architect-for-genesis-8-females , not the Product Library link as the latter will work only for those who have purchased.
    Did you uninstall the product through DS before trying to install through DIM?
  • jodhan322jodhan322 Posts: 65
    I first used the the istall tab in daz studio, then I unistaled it. I then used DIM. Same effect.
  • barbultbarbult Posts: 26,410
    Pose Architect is a set of Pose Control dials that you access from the Parameters pane.  Please refer to the readme to see instructions for use.
