EJ Valeria for Genesis 3 Female(s) [commercial]
nicsttnicstt Posts: 11,715
edited July 2015 in Daz Studio Discussion
http://www.daz3d.com/ej-valeria-for-genesis-3-female-s
Well, I was pleased for a minute or two; a new G3F, then I checked the included files below and no genital textures http://docs.daz3d.com/doku.php/public/read_me/index/22349/start
Without that option, I'll be unlikely to purchase a character. I wonder if there are many like me? I produce more that don't need than do, but it's annoying to start something then realise one or two image out of a series won't work.
Post edited by fixmypcmike on
  • nicsttnicstt Posts: 11,715
    hmmm, no edit button? Why produce a morph, but no texture?
    The morph is a vaginal crease morph that is very different from the Geo-Graft Genitals.  The genitals replaces a section of the hip with a new model and that model is not UV mapped to be able to use the figures torso map like the Genesis and Genesis 2 Geo-Grafts where.
    Yes, thanks for your post and am aware of that. Was just a comment.
    Although, the morph doesn't apply on the Tatijana character, also by the same artist for G3F, so doulbly cautious.
  • EmmaAndJordiEmmaAndJordi Posts: 952
    edited July 2015
    Hi! :)
    We did not include the texture for the geocrafted genitalia because it may need a new set of textures with tattoos with and without the geocrafted genitalia and with so many options it may be very confusing.
    So our solution was to provide a custom morph for genitalia that makes the crease as jestmart says. That way you can set it on and off, with whatever tattoo or texture of the character. Also, as it is a custom morph you don't need any other requirement, you don't need the geocrafted genitalia.
    Maybe if at some point if we can find a way to mix the geocrafted texture with the tattoos and other options we may include it, but we will always keep the custom genitalia morph because it solves the problem for many users that just want the external look. But we are always open and watching and wanting to include every possible option.
    It's strange that the morph is not working for you in Tatijana. We have tested it in a clean Library and it works.
    Did you use the icon as shown here in this image to apply it? Please try, we will help you to solve any problem why it's not working, so don't hesitate to ask for any info or help! :)
    See this screenshot: https://dl.dropboxusercontent.com/u/8780054/Tatijana.jpg
    Post edited by EmmaAndJordi on
    Something that can happen is that if you dial the morph in Hip/Real World called Genital Detail, directly before applying the custom genitalia, that dial won't work.
    Because you have to apply the custom genitalia as in the screenshot with the icon called "EJ Tatijana Genitalia Apply" first. Then, if you like, you can go and dial the Genital Detail dial to apply it more or less to your liking.
    Without applying the "EJ Tatijana Genitalia Apply" icon first, DAZ Studio may not know which genital to apply, in case you have several.
    Valeria just uses the icons to apply or remove it, the Genital Detail won't have any effect. We have decided to do it this way to make it easier, so they apply like the nails and fangs, on and off with the icons.
    Thank you for your response, I'll try it and let you know with the morph. I own something like 40 of your genesis 2 characters; as you can image (from the number I own) I find the quality amazing. I would be very happy with the option even if the tattoos cause issues to have the option to use the genital textures, or not, and likewise with the tattoos.
    Due to the nature of the way the genitals are mapped with G3F, creating our own is problematic, to say the least; none of the templates released that I have seen, show where the genitals fit in relation to the torso; so although it is easy enough to work out what a template would look like from existing genital textures, knowing where to place it would be an extremely frustrating exercise in trial-and-error.
    And sadly, the templates Daz have released, don't include the genital templates, nor a template showing where the templates fit within the torso.
    Thank you very much nicstt! :) We will look at this, we have to look deeper on how to texture them and how to make them mix the best possible with the rest of the body. If we get to solve it, we will include the texture. The more complete the products are, the better :)
    Just did a quick test, and double clicking the morph after loading the character does not apply the crease. The only dials I see under Genitals, are shown in the image; all to do with glutes. Doubling clicking the nipples, for instance applies them.
    525 x 1119 - 228K
    edited July 2015
    It seems something changed in the base files of Genesis 3 and it doesn't work for all people.
    We will do an update soon so in Tatijana works as in Valeria, without the interface of the Genital Detail.
    Thank you so much for pointing this out.
    Welcome. :)
    Nicstt, the update is made and you can download Tatijana again and you will be able to use the icons for the genitalia
    edited July 2015
    Great!
    All I need now is the genital texture. wink
    EDIT:
    Yup it works great.
    Post edited by nicstt on
    edited July 2015
    I noticed a dial, in an odd location with the other figure, and I did get the update last night for Tatijana (before pealing the "new" stickers off of the icons). Yet to even look.
    http://www.daz3d.com/forums/discussion/comment/863961/#Comment_863961
    (EDIT)
    Same for Tatijana, I think. Is this the dial? (it's only visible in the parameters tab, with "show hidden" enabled). Err, same dial, same name, and it's there on regular G3F. Just in an odd location.
    514 x 652 - 47K
    nicstt said:
    Great!
    EDIT:
    Yup it works great.
    Glad it works now, thank you! Yes we will look at it although it is not easy, but will look to make it :)
    (EDIT)
    Yes it is because it is hidden. You may have the Show Hidden Parameters option enabled. It is hidden to not clutter the interface. It is common for now, although we may do different shapes for that or other morphs through time. Being hidden is required so the hip/real world section don't gets overcrowded with genitalia morphs. It's also to leave more neat the standard morphs and the morph packs that are a product.
    As more or less the genitals are the same, they are common, but anyway it may change in next characters, being several.
