Anything Glows - weird !!!
FettbemmeFettbemme Posts: 319
edited March 2024 in Carrara Discussion
I made a Neontube with IES, I don't know why it has a selfshadow on the floor
(scene download)
Post edited by Fettbemme on
  • DiomedeDiomede Posts: 15,410
    Been a while since I tried anything glows.  Is there an offset setting for the distance between the glowing object and the start of the light?  maybe 'offset' or 'standoff' or 'minimum' or 'start'?
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,562
    Anything Glows needs to be limited to a set of facets, making all the glowing surfaces on a big object does not give accurate shadows
    eg a Chandelier you will not get a good result making all the bulbs on a single mesh glow but if each buld a single object with a unique name it will work
  • FettbemmeFettbemme Posts: 319
    edited March 2024
    I think the IES is the problem
    I tried another IES and no selfshadow, but also a little weird
    2000 x 844 - 221K
