Looking for a specific type of jacket
JediKnight2140JediKnight2140 Posts: 38
edited March 2024 in Product Suggestions
Is there a jacket that looks relatively similar to the one Max is wearing in Stranger Things season 4? Preferably g8f?
For some reason I can't upload a picture of the one I'm talking about. Either that or I uploaded it 7 times. Either way, it's the brown one she wears towards the end of the season.
Post edited by JediKnight2140 on
  • memcneil70memcneil70 Posts: 5,622
    It looks like a suede bomber jacket. The material could be adjusted by a shader, but I have never watched the show, did she put her hands into the pockets from the backside or from the top and was it zipped up?
  • FirstBastionFirstBastion Posts: 8,055
    This will be a challenge.  Most Gen8 female type jackets in the store have a different look. More crop, no pockets.
    This one is ancient for M4, will need a cross fit conversion,   https://www.daz3d.com/fur-leather-and-stripes
    and then you need a modern suede retexturing.
    https://www.daz3d.com/leather-collection-suede
    I had my D|S with the fullest library of clothing (non-Gen 4) open and decided to try a search of outerwear/tops.
    The closest one to a bomber jacket was https://www.daz3d.com/ma-1-flight-jacket-for-genesis-3-female-s but as you can see from the promos it has pocket flaps on the torso sides for the hands and pockets on the upper sleeves. It does have the classic elastic waist band on the bottom and while it has textures, it would need a suede shader and to be brought up to Gen 8 or auto-follow might work with it. There are three versions of it too, open, closed, and liner only. As someone who issued these in the U.S. Air Force, I can tell you it is accurate.
    Another which is next close was https://www.daz3d.com/dforce-hnc-leather-jacket-outfit-for-genesis-8-males but does not have patch side pockets, but slits for inserting the hands. This does not have the stretchy look at the bottom though, and would need a suede shader. Since it is for G8M, auto-follow should work.
    One other jacket https://www.daz3d.com/traveler-for-genesis-3-males which is also DAZ+ meets the shape, but has a set of upper pockets and slanted lower pockets. But it has/had two material packs, https://www.daz3d.com/aimlessly which seems to have a dark brown suede look for the jacket. The other texture set is no longer in the store, One Way Ticket, but the textures for the jacket are not brown. Maybe at Moyra's store at Rendo it is there? Again, it is a G3M jacket and maybe auto-follow would work for a G8F? Even if it doesn't, this is a nice set for hiking for the guys. I have used it on G8M.
