Hair used in Satsuki for Genesis promo?
Anyone know what hair is being used here?
https://www.daz3d.com/satsuki-for-genesis
Going to make some purchases later today, and I'm definitely considering this one...
Thanks
Post edited by ttimm on
Thanks
Sorry, was having a tough time finding it at first, so I posted, but one more search and I found it (ToXic Moonsong).
Thanks anyways :)
Toxic moonsong is a texture set (ie and add on product) for Moonsong hair https://www.daz3d.com/moonsong-hair
I've wondered about this hair before in the past too. Would it work well on a G2F figure, do you think?
@Chohole, Thanks! I might have purchased that and been left a bit puzzled! I REALLY appreciate the heads up!
I am probably the worst person to ask right now as I have my tippie toe in the water and am just tinkering and watching/reading whatever tutorials I can dig up. As you can tell, I was ready to purchase a texture thinking it was a mesh (derp! :P )
Having said that... :) ...I will try it if I get it(them). I am thinking that if you fit/parent it to your G2 figure, and then scale it if need be, it *could* work... I will post back if I purchase it and get it to work :)
Autofit to a non-supported figure often distorts some part of the hair which is also true in this case. In that case parenting the hair to the head and adjusting parameters manually will usually work, as shown here.
Thanks for that Taozen. I actually think the Autofit G2F pic looks pretty good.
Well the hair above the ears looks fine, some may say even better, but the rest below is distorted. You can however smoothen the sharp angles by applying SubDivision to the hair like here but the style is not quite the same (but then, some may like that style better).
