Actual Eyes 4 showing as white after rendering
Hi
I have tried searching for similar threads, but only found one which referred to Actual Eyes 4 showing as grey/white in the viewport since they use procedural shaders, and that they will show correctly when making a render.
I see them as white in the viewport but also as white after rendering. (see attachment)
I have tried reinstalling Actual Eyes 4, and also don't see any of my other products acting like this. I have installed all my products using the default paths.
I use the Iray render engine, but have also tried some of the other engines. Same result.
Does anyone have any idear what might cause this?
Thanks in advance.
Henrik
  • Richard HaseltineRichard Haseltine Posts: 108,598
    Have you tried 3Delight? If the eyes use procedural shaders they will be renderer specific, and on an older product that will mean 3Delight.
  • Thanks a million, that worked. 3Delight engine did the trick.
    1008 x 998 - 1M
