Editor all white
Drogo Nazhur
I just upgraded to the latest version and the editor background and tabs are all white instead of the normal shades of grey. See attached image. I completely shit down and PC and restarted it but it isn't going back to normal. Somebody please help.
Post edited by Drogo Nazhur on
That usually means that DS was still running when you updated it. Make sure DS is not running then uninstall and reinstall it.
Where do I find DAZ to install?
Would this also mean that I would have to re-install all of the products that I purchased?
In my install manager I have over seven thousand products installed. What do I uninstall and then re-install to correct this problem?
Just the Daz Studio application, which should be at the top of the Installed tab (and the Dynamic Clothing Control plug-in, if you have that)
This issue has nothing to do with other products but Daz Studio only. You just need to re-install Daz Studio 4.22. that you've just updated in DIM - Installed tab. Make sure DS session is completely closed (in Task Manager...) before reinstallation.
