(Released) - Cila Hair for Genesis 9 [Commercial]
Toyen
Now available - https://www.daz3d.com/cila-hair-for-genesis-9
Note: This hair does NOT yet use the new hair shader that just came out two days ago (I promise my next one will!). It is however compatible with the shader since this is a strand-based product so you can apply it yourself and play with it.
The product page says the ponytail can be simulated, but the product does not mention dForce in the title or description.
The simulation is not nescessary - the ponytail is poseable. It's just an added detail should you wish for more accurate collision. If the hair can be used without simulation I don't like to use the dforce label. If it has to be simulated/draped in order to be used I call it dforce since that's what most customers imagine under the label :)
