What do you think about this render?
in Art Studio
Hi, Im benniger in DAZ, but I interest in constructive critiques. This is my render What do you think?
Iray render?
If so are all surfaces/materials converted to Iray ones?
Yes IRAY render. All have Iray uber.
Okay...then try playing with some of the settings on the lingere. The bra, especially, looks more like plastic than cloth. In a PBR, like Iray, that's usually because things like Diffuse color are too 'white'. 0.8 is pretty much the highest it should be. Also, over all light levels are bit too 'hot'...is the default headlamp on the camera turned off?
Oh, interesting. Its my set of lights, no headlamp.
If the headlamp is off, then some of the lights are too intense...at least for the setting. Try pulling back the key/fill (I'm assuming it's a 3 point setup or similar).
Ok I take the tips. Yeah its 3 lights, with 2 point light for hair. The hair is blonde, for me in the preview is too dark scene.
The hair color problem sounds more like a settings mismatch.
