Frieren hair and maybe outfit?
Hello! Any suggestions on products to get Frieren's hair?
And how about the outfit? I'm guessing the outfit's a much taller order, that 'double bell' sort of look is quite distinctive, but if I can at least get the earrings and the hair then maybe I could kitbash the outfit on my own.
  • GordigGordig Posts: 10,613
    For the hair, you could start with Long Pigtail Anime Hair, maybe keep the pigtails and replace everything else with something middle-parted. If you're looking for something a bit more realistic, Kanade Hair might do. You could use the cloak from dForce Stylish Cleric over a more appropriate tunic, and I'll scroll through my library to see if anything fits.
  • DiasporaDiaspora Posts: 498
    edited February 2024
    Kanade Hair is damn near perfect! And wow, the stylish cleric outfit is actually nearly spot on!
    Wow, I guess that's the power of such an enormous and diverse library.
    Thank you!
    Post edited by Diaspora on
  • NinefoldNinefold Posts: 256
    Lady Littlefox's Kinley Hair is also quite similar to this character's hairstyle. It's dForce, which might be a plus or a minus for you.
    I actually didn't even need to check my library to find those. I knew the second I saw your image what would work, and only needed to look them up to verify the names and get links.
    I really appreciate someone with such an encyclopedic knowledge finding my post so soon.
