Position coordinate transfer
Is there an easier way to transfer the pose and the position all at once? I've tried a few things and gone hunting on the forums/google and cant seem to find an answer.
Right now I copy the orgional character -> paste pose to new character -> Manually set the location translations and rotations to match the origional, delete the origional.
Apologies if there is a simple answer to this adn I have been too dense to find it
Riversofts assembly line suite has such a handy feature
Saving a Pose Preset (default) from the original character and then load it onto the new character will also do.
Thanks!
what makes Riversofts product stand out is you can toggle so saves without all FaceRig poses so pose also loads so much faster.
Yes you can do this manually, but the time it takes for each pose to turn those off is alot.
Using VisualMenus bring up Riversofts script and select what i want, and 3 seconds later onto next task.
Manually i'd be there a while.
Courtesy link: https://www.daz3d.com/assembly-line-pose-automation-kit
