not enough genesis 8/9 (female) tactical/military outfits.
    Why don't you just buy the two outfits that you linked to?
    because they are OBJ and they are not meant for daz studio as outfits
  • GordigGordig Posts: 10,805
    Every outfit made to use in DS began life as an OBJ.
    I meant if there will be something like that in shop i will buy it as a ready to wear cloth
    Ahh, well I just saw it was an outfit with Genesis 8 Female in the title - I am not familiar with the products sold on Artstation. Pretty sure that Daz has an exclusivity clause for vendors and so they would not be able to sell here without shutting down their Artstation store (and vice-versa). Besides, presumably that vendor is not interested in selling Daz Studio products if they are releasing G8F products as objs anyway.
    Other than the "mesh hoodie" I am sure I have seen similar(ish) items in the Daz store tho - maybe the clothing and props in the Delta Alpha Zulu Bundle?
    Also, you should probably edit your first post and move it to the Product Suggestion forum as that is where such posts are normally filed under.
    Don't forget to include Genesis 1, 2 and 3 in your search. You'll find a lot more to choose from.
    I still use M3/V3/A3/H3, Generation 4, and all of the Genesis generations. A little help with the shaders and we've really got something! So I also look at all generations for costumes.
    I also mix and match all the time!
    That said, have you seen Herschel's outfits? They seem fairly close to what you're looking for.
    these clothes have a lot of props which will ruin my fbx export
    If you want to export them to fbx then why are the objs from the artstation store not suitable? Surely whatever you are importing them into can cope with objs as easily as fbx?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,568
    edited February 2024
    the obj's can be imported into DAZ studio and fitted with the transfer utility
    you may need to do weight paint editing
    as for props export them separately at 0,0,0 and parent them or if it's a thirdperson player in Unreal create a socket and add them in the Blueprint
    Daz's exclusivity applies to products, not stores. Daz PAs can't release the same products they release to the Daz store on other stores, but they can absolutely release different products.
