Figure Metrics works not correctly
Good evening dear community,
I have the following problem, I bought the Measure Metrics tool and wanted to use Figure Metrics to adjust the individual parts of a character to the measured values, only that when I look under Measurements many of the values have no box to change them. Then I looked under Configuration and there, see picture, many things are not linked. I then looked for the Measure Metrics entries for the individual things but they don't exist.
Now it must be said that I also use Bodymorphs and maybe they overwrite exactly the things I need.
Maybe someone has an idea what else I can do.
You need to select a node (usually the body for morphs, or a bone for transforms) by clicking the button, then once you have a node click the Select a Property button and pick a morph or transform. Be careful not to pick properties for the measures you wish to adjust that will compete, otherwise the process will just go in circles and not achieve anytbing useful.
