how do i import a 3ds max figure into DS 4.8
How do I import a max figure into Diaz studio and keep its rigging and texture?
    Simple answer...you don't.
    Rigging will not transfer, even on G3F, it's close but not quite there using Collada.
    Textures are somewhat better...you can get them but not always.  FBX and Collada are pretty much the best bets for textures, but even obj can, with careful placement/loading of them.  Besides, unless you are loading the textures from the folders you want DS to use as the final folders, you are going to manually reload them, anyway.
  • TSasha SmithTSasha Smith Posts: 27,330
    How can I learn how to rig a figure from scratch?  are there any tutorials anywhere?
    edited July 2015
    In this thread, there is a basic rigging tutorial.   It deals mainly with props that have moving parts, but the basics are the same...except more bones and then fiddling with the weight maps.
    www.daz3d.com/forums/discussion/57873/
    Post edited by mjc1016 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,298
    edited July 2015
    you can into Carrara and iClone 3DXchange if you have them.
    but I have had no luck whatsoever with DAZ studio even dae (collada) unless DAZcollada from carrara but rigging does not stick after save
    mjc1016 said:
    Sim
    Is there a max version of Genesis 3 female?
    mjc1016 said:
    Sim
    I do hope you posted that question as a joke, because if there was a version it would be illegal.
    Chohole said:
    mjc1016 said:
    Sim
    Not looking for an illegal version but wondering if daz made a version since they advertise it on their front page that content works in Maya and max. Guess one would need to use studio to import into those programs.
    I know they have iClone versions of Genesis 2
    not sure if there is a MAX store as such but there is a Unity asset pack too of game versions too DAZ did
    well I only had MAX trial for 30 days over a year ago and got V5 in textured rigged and animated via FBX
    https://www.youtube.com/watch?v=0W4FAx7pFr4
  • Richard HaseltineRichard Haseltine Posts: 108,647
     Not if your goal is to get a rigged figure into 3DS. Alembic saves a file specifying how each crtex on the figure moves, but that's all - it's just a moprhing lump of polygons, not a figure any more. FBX would probably be your best bet for going from DS to 3DS.
