Shoe fit issue with Toon Heroes for Genesis 9
in The Commons
I purchased the toon heroes for Genesis 9 recently and I'm having trouble when I add shoes to the character.
The shoes fit and all, but they seem to be taking the form of the toes which makes it look odd.
At first, I thought it might be a compatibility issue cos I was using Genesis 8 shoes, but then I bought a Genesis 9 shoe and it still has the same problem.
Is there a workaround for this?
You can try to dial the body morph out.
Or see if smoothing towards base shape can solve it.
Or the best solution, but that also requires most work, create a dedicated morph for that character as a substitute to the autogenerated morph.
It's a common isssue on stylized and toon characters...If you know a sculpting tool e.g. Blender... the best way is to fix the distortion in Blender and import the shape to update the full body morph on the shoes.
An alternative: do not dial Toon Vixen's body morph (Toon Hero Body), you shape the character's body with morph products, e.g. Shape Shift...
