Edit shader button?
Hi all,
Previous versions of DAZ Studio had an "edit shader button"
Where can this be found in DAZ Studio 4.8?
I'm trying to edit an existing shader, but I can't find the button...
Much obliged and many thanks,
Me
  • KhoryKhory Posts: 3,854
    I think maybe what your looking for would be found by selecting the surface tab, then the little edit tab at the top of that. Then you will be able to edit any of the settings.
  • Hi,
    Thanks for the answer.
    The editor tab is not what I'm looking for however. I would like to edit some of the properties of the shader itself:
    I'm using PWtoon and I would like to add a seperate controler for the opacity of the outline. Right now, that isn't there.
    Also I'd like to change the behaviour of the outline: when to draw it, and when not to draw it.
    Thanks a lot,
    Me
  • SpitSpit Posts: 2,342
    I think you're looking for Shader Mixer? You can access it through menu Window/Panes (Tabs)/Shader Mixer. If you want a toolbar button for it you can customize, create a new toolbar, and drag the icon from the menu to your new toolbar in the cusomize window.
    I'm not sure if you can customize a pw shader but I guess you'll find out either way.
  • Hi,
    Thanks for the reply!
    Shader mixer could be it, however when I open it it appears to load up blank... How do I get it to load the shader I want to edit?
    Thanks a lot,
    Me
