Distorted Genesis 9
in The Commons
Hi, all my Genesis 9 models are appearing in my DAZ as this distorded shape. CAn anyone help me sort it ouy? I have uninstallled all DAZ and rreinstalled three times, to no avail? Do I have to format my PC ?Is there a way to reset the genesis 9 model base. My gensis 8 and all below are perfect. Just genesis 9
Please put the Viewport into a non-textured Drawstyle if you need ti show a nude figure.
That is a morph with a non-zero default value. Edit>Figure>Zero>Zero Figure Shape should gt it back to the base shape, then if you go to File>Save As>Suport Assets>Save Modified Assets the list of things to save should enable you to identify the culprit - cancel the dialogue, to avoid any risk of modifying something that shoukld not be touched, then uninstall the problem shape and check to see if there is an update; if not contact the author.
Thank you, I have freshed installed DAZ on a clean PC and yet it does this distortion to the G9
Yet your problem allowed me to zero the shape and add morphs, a good work around
Thank you very much for your advice
using the same content instalaltion or fresh content installs too?
It happened a few weeks ago, and I eventually formatted my C drive, fresh install of DAZ, and it was the same.
Just the DAZ system itself on my pc, I can't explain it.
I did the install 3 times, to try and fix it, nothing did, I am happy to use your workaround when I use G9's as it works.I can't see a solution.
So I thnk you, I just zero a G9 figure, then because I can't just load a G9 characer, I use the morphs and its as good, just slower.
Cheers
