testing... testing...
2
  • McGyverMcGyver Posts: 7,085
    Okay... No love for apple? Edit icons show up just fine in Windows... Maybe if I tilt my iMac sideways...?
  • larsmidnattlarsmidnatt Posts: 4,511
    the formatting isn't that great on windows either. the edit gear is halfway outside the box as it is.
    Sweet Jeebuzz... It does work... you have to mouse over your posts... your cursor has to be inside the post field to show up...
    Well, on a Mac... I'm pretty sure on the Dell it just showed up...
    I normally scroll using the scroll button and off to the side.
    on windows you need to mouse over posts as well.
  • MelanieLMelanieL Posts: 7,791
    edited July 2015
    Trying to figure out the tiny image thing - just ignore me...
    Ah so you CAN do that! I attached the image as "Attach a File", then copied the url from that (= http://www.daz3d.com/forums/uploads/FileUpload/64/548b21e2f67c87bee61d0292772a9a.jpg) then inserted that inline as an image. Was massive.
    So then edited to restrict the width to a more reasonable one. Deleted the original attachment, hey presto and inline image of my chosen size!
    Disadvantage: clicking on it doesn't show the image full size (as the attachment method does). Also it's a bit time consuming.
    ETA: Ah now learnt that if you add the URL in the Link tab as well as the Image Info tab the full-size works too...
    Post edited by MelanieL on
    edited July 2015
    Lets see if this works...
    This is a confusing method and far worse than the lack of inline image posting... So there is no way to upload from my computer?
    Post edited by McGyver on
  • srieschsriesch Posts: 4,243
    You can just attach the image ("Attach a file") link below the edit window.
    Testing again...
  • TSasha SmithTSasha Smith Posts: 27,376
    Did somebody leave a litter box in the corner of the thread?  There is a lion cub using it.
  • Panzer DragoonPanzer Dragoon Posts: 11
    edited July 2015
    deleted
    i dont see a delete button
    Post edited by Panzer Dragoon on
    Testing again...
    edited July 2015
    I'm testing to see if the banner can be made smaller...
    Yeah... that looks smaller now!
    edited July 2015
    EDITED old post to attach image
    144 x 213 - 11K
    Post edited by sriesch on
    edited July 2015
    2
    EDITED this post a second time to attach an image.  The first time It didn't work.  is it still failing?
    Hmm.  This same image is attached twice.  The first attachment doesn't work, the second one does.  What's the difference?
    144 x 213 - 11K
    144 x 213 - 11K
  • frank0314frank0314 Posts: 14,763
    You can make the banner as small or big as you want
    As long as it isn't more than 100 pixels high and I think it is 1024 pixels long
    I don't really know positivly the size limits. I only tried a couple sizes. One large and one small. Currently I'm using 100x1024
  • StratDragonStratDragon Posts: 3,278
    cant edit the title of a post I made, It wont save.
    You can ask one of use to change it for you. We have reported it to DAZ
    edited July 2015
    Just testing posting an image from my "image link thread"... Via iPad
    What at is the Max size to avoid resizing? Or is resizing not a big deal?
    Post edited by Chohole on
    Automatic resizing is not working correctly at the mo, and having to do it manually is a bit of a PITA, if we get too many
    Currently, what are the maximum dimensions to avoid having the moderators have to manually resize the images?
    We are actually resizing to 800px, but 1000 seems a fair size.
  • none01ohonenone01ohone Posts: 862
    edited July 2015
    Just testing.   indecision
    Hmmm html.
    Post edited by none01ohone on
    new post with attachment at time of creating post
    144 x 213 - 11K
    edited July 2015
    new post with no attachment initially
    EDITED to attach image after the fact
    144 x 213 - 11K
  • RAMWolffRAMWolff Posts: 10,368
    I am a little bouncing ball , made of <var><cite><span dir="rtl"><strong><big>p</big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big><span style="background-color:rgb(0, 0, 0)">u</span></big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big>p</big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big><span style="background-color:#000000">p</span></big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big>y </big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big><span style="background-color:#000000">f</span></big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big>u</big></strong></span></cite></var><var><cite><span dir="rtl"><strong><big><span style="background-color:#000000">r</span></big></strong></span></cite></var>.... devil
    LOL ..WTF??
  • Richard HaseltineRichard Haseltine Posts: 109,088
    RAMWolff said:
    LOL ..WTF??
    You probably didn't click the Source button before pasting your HTML in.
  • MN-150374MN-150374 Posts: 923
    edited September 2015
    Test Anchor1
    Test Anchor2
    Test Anchor3
    Test Anchor4
    Test Anchor5
    Test Anchor6
    Seems to work fine with Firefox 40.0.3 and IE11. :)
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
              aaaaafaaaaaaafaaaaaa
              aaaaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
     aaa       aaaaaaaaaaaaaaaaaa
     aaa      aaaaaaaaaaaaaaaaaaaa
     aaa     aaaaaaaaaaaaaaaaaaaaaa
     aaa    aaaaaaaaaaaaaaaaaaaaaaaa
        aaaaaaaaaaaaaaaaaaaaaaaaaa
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    - Anchor4
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
    - Anchor5
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
    - Anchor6
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
                  a          a
                 aaa        aaa
                aaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
               aaaaaaaaaaaaaaaaaa
                aaaaaaa  aaaaaaa
                 aaaaaaaaaaaaaa
      a         aaaaaaaaaaaaaaaa
    Go Back or Move on
    Post edited by MN-150374 on
