Mid Century Modern Clock
I created this totally in Daz.  I was looking for a clock like this but couldn't find it.  You can adjust the hours and minutes.  Please let me know if there are any problems.  I tried to export the file and create an .obj but I don't know what I was doing wrong.  I couldn't get the colors to export and when I tried to bring it in and recolor it, it was one big object and not individual pieces I could color.
Anyway, I hope you like it.
  • UnseenUnseen Posts: 765
    Thank you very much. Very nice!
  • perlkperlk Posts: 854
    I don't know if you can do UV mapping in DS. But it looks great, thank you!
  • No, though you can use Sahder Mixer to project textures (at least for 3delight, Iray can use decals)
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,399
    you can assign surfaces with the geometry editor
    you should already have groups with the primitives used so can select by group and create surface from selection for each one
    You should already have groups with the primitives used so can select by group and create surface from selection for each one
    Thank you.  I'll give that a try.
