The problem with a mirror reflection
calaopiecalaopie Posts: 215
I tried to put on nails a mirror reflection ane succeeded a couple of times.
Now when he tries to apply this effect to the second form of this effect is not the same.
What am I doing wrong?
example
    DAZ Studio, and if so, what renderer, Iray or 3Delight?
    Is this nail texture a shader, if so, which one?
  • RenpatsuRenpatsu Posts: 828
    How did you apply the shader/preset to the second? If you tried to do copy -> paste via the surfaces pane then the actual shader won't get copied, just the parameter settings. In such a case you would first have to apply the base shader to be the same and then copy/paste or - as an alternative - you can save the surface that is looking good as shader preset and apply that one to the other figure from the library.
  • calaopiecalaopie Posts: 215
    edited July 2015
    It is not texture (I think)
    At the beginning of the resulting texture of the nails that loaded the settings. Then I remove the texture and replaces it with normal color from the base.
    On the right you will see the effect, nice reflection, maybe a little at large but good.
    On the left the same settings but ne I manage to get a similar effect
    Settings on the left are for the nail on the right and vice versa.
    800 x 600 - 688K
    984 x 891 - 119K
    800 x 600 - 688K
    984 x 891 - 119K
    Post edited by calaopie on
    Glossiness at 65% is too low for 'sharp' reflections.
    Ambient at anything ABOVE 0 is going to torpedo any 'realistic' look for specular/reflections...they will 'glow' in the dark/low light and look very odd.
    And the big one...is there actually anything to reflect?
    Yes, you are getting a specular response, but I'm not really seeing any 'reflections', in either set.
  • srieschsriesch Posts: 4,243
    glossiness parameter difference maybe?
    edited July 2015
    Simple solutions are always the best. The creation shaders worked, I set it as ambient color "0" and looks good
    Thank you all for your help
