Chonk - missing thumbnail in Smart Content
vonHobovonHobo Posts: 1,715
I have tried everything to get Chonk the Skeleton to show a thumbnail. All the files are in the directory, just like the other two products.
These are 3rd party products, and I installed them by copying the zip file to the Package Archive directory. All three products work fine, I just can't get the thumbnail to show up for Smart Content.
Does anyone have any idea how to fix this?
  • NorthOf45NorthOf45 Posts: 5,713
    Is that the Product View? If so, do you have a thumbnail file in the Runtime/Support folder? If you installed with DIM, there will be a generated metadata file (I doubt the 3rd party products have any of their own). The thumbnail file must have the same filename as that metadata file.
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    i'll link this post to the discord server this vendor frequents. I do believe they are a member here still and can answer you.
  • vonHobovonHobo Posts: 1,715
    Thank you. I double checked the installations and all the files are there with the correct names.
  • lou_harperlou_harper Posts: 1,163
    I installed it using Content Wizard and the thumbnail is there. https://www.daz3d.com/content-wizard
    Thanks, I will check out that product.
  • TomhipTomhip Posts: 579
    I sometimes find products in smart content that are missing all previews and show that explaimation marks icon on every item inside. Reinstalling them via DIM usualy fixes it.
    The creator was not able to come in but has been made aware of the problem and is currently being fixed or had been fixed. They suggest contacting them on their sites forum if you need to speak to them.
    Yes. Thank you. They fixed it already.
    yes
