SpreadSheet Itemized Order List
Tripod2goTripod2go Posts: 10
I know this thread is old but not sure where to ask this. In July 2010 I downloaded a ice itemized order list in a spreadsheet format with dates, item name etc ad the reset link. I went to update the list and can not locate it. I understand DIM sort of replaces this but it doesn't have all items purchased, installed not installed or downloaded, date of purchase with order number.
This is very useful information especially for offline reference.
Am I overlooking the report link or was this just removed?
  • TSasha SmithTSasha Smith Posts: 27,267
    That would be cool to have as long it does not total the amount I spent here. Gulp!
    Are you talking about your Product Library
    https://www.daz3d.com/downloader/customer/files
    https://www.daz3d.com/sales/order/history/
  • larsmidnattlarsmidnatt Posts: 4,511
    I think they want a consolidated list they can keep offline.
  • SpitSpit Posts: 2,342
    That was a very useful program but the downloads page completely changed format and is now the first link Chohole gave you so the program no longer works. You can sort the DIM files in several ways and save as comma delimited txt files, but I don't know if there's a way to get the other info into the files. It's all there in DIM but accessing it in batch I don't think is possible.
  • cunningfcunningf Posts: 32
    Is this what you're looking for?
    http://taosoft.dk/software/accm-daz/
  • IceCrMnIceCrMn Posts: 2,319
    I just now downloaded and tried that program, it doesn't want to download my history :( it keeps telling me that I'm not logged in,,even though the right side pane shows my account page and I am logged in.
  • TaozTaoz Posts: 10,259
    Hm, never seen that error before.
    Where did you install the program, and which OS? Currently it will not work correctly if installed in any of the "Program Files" folders in Win 7 and later, you should use the "ProgramData" folder (usually hidden) or some other folder.
    The History login and the browser login are actually two separate logins sessions, so the browser may say you're logged in even if you're not logged in in the history part of the program. And, if you're already logged in an IE browser window, the browser in the program will also be logged in by default and vice versa, as it shares login and other data with IE (it's a clone of IE).
    edited July 2015
    I decompressed the zip to my Desktop and ran the executable from the applications directory as an administrator. I'm running Windows 8.1 Pro.I don't use IE, I'm a firefox fan, but I do have it installed.
    EDIT: Here are several screen shots of the errors
    1479 x 965 - 236K
    1477 x 963 - 237K
    1331 x 868 - 161K
    Post edited by IceCrMn on
    because I have to enter my login credentials to make this app work, I was wondering what sort of security measures are in place to prevent my username and passwords from getting leaked? I would be very unhappy to have someone login to my account and download all the stuff I've purchased or worse, use my stored payment information to make purchases.
    OK. Here's a DAZ login tester, try if you can log in and stay connected:
    http://taosoft.dk/temp/DAZLoginTester-1003.zip
    edited July 2015
    same problem :(
    edit: the error.log
    7/6/2015 11:58:41 AM - Program started...
    7/6/2015 11:59:00 AM - Start test... (30 sec)
    7/6/2015 11:59:01 AM - StatusCode: OK
    7/6/2015 11:59:02 AM - StatusCode: OK
    7/6/2015 12:00:39 PM - Program closed...
    1171 x 850 - 166K
    It's using Microsoft's .NET library to log in via HTTPS, should be as safe as logging in with your browser. And no user data is being sent anywhere except to DAZ.
    If you save your login the data will be encrypted (in the login.dat file), don't let anyone get access to that file as they can use it to log in if they have a copy of the program.
    ok,,thank you, I'm fine with that. :)
    same problem :(
    Looks like something is blocking the program from accessing the internet, like a firewall or AV program. It may let the built in browser connect as it will identify it as IE which is usually whitelisted by default, while blocking the history login.
    Try to disable anything you have of that kind, temporarily, and see if that helps.
    edited July 2015
    BTW, any non-alphanumeric characters in your password?
    Post edited by Taoz on
    edited July 2015
    Firewall and AV disabled, and reboot ,, I tested with both the app and with the login tester, same problem.
    Maybe someone else could give it a try and post back with their results to see if it's just my system configuration.
    edit: I had a look through the Windows Features config and this is what I'm seeing ( see attached screenshot). Shouldn't the Windows Communication Foundation features be activated by default?
    584 x 1005 - 151K
    edited July 2015
    No, that's not necessary here.
    But I just checked the Login Tester code (years ago I wrote it, so I've forgotten most of it). The statuscode OK actually indicates that the DAZ server responds, but it won't let you in for some reason.
    I suspect that there are some non-alphanumeric characters in your password which are not being converted correctly. DAZ may have expanded the range of allowed characters which used to be rather restricted, so you maybe using some that the program currently doesn't handle correctly. It's easy to fix.
    Yes, I use a NON alpha-numeric password a rather lengthy one.
    Yea, I guess that's the problem then. Will get back as soon as it's been fixed...
  • achimsachims Posts: 78
    edited July 2015
    I'm using Account Manager for DAZ 3D with Windows 8.1 ( 64 bit ), Firefox 40.0, Norton 360 and a NON alpha-numeric password.
    Got my full (?! ) History from DAZ 3D.
    Well, Full?
    DIM says 8.422 "Items"
    Account Manager for DAZ 3D says 5.557 ? ! ?
    Post edited by achims on
  • taosoft_daztesttaosoft_daztest Posts: 3
    edited July 2015
    Well, Full?
    The Account Manager only lists products, i.e. 1 entry for each product. DIM lists files (some products have more than 1 file).
    Account Manager gets its data from the Product Library's json data, so it lists the same products as the Product Library (meaning some bundles are missing, unfortunately (unless they've fixed it recently)). But the individual products contained in the not-listed bundles should all be there.
    But maybe I should replace "Items" with "Products", to avoid any confusion.
    Post edited by taosoft_daztest on
    edited July 2015
    OK, think I got it fixed. Currently I've just updated the Login Tester, if you'll give it a test run:
    http://taosoft.dk/temp/DAZLoginTester-1004.zip
    If there are still problems, please reply to support at taosoft.dk
  • Tripod2goTripod2go Posts: 10
    Gee thanks guys I'll start reading and looking. In 2010 it was found at
    DAZ 3D > My Account > Itemized Order History
    A combination of product library and order history. Example is listed below.
    item Date order
    1 Bryce Masters Series: Cloud City br_sc003 2010-07-10 07:29:17 FILLED 6131875 Reset
    1 Maximum Overkill ps_ac3988 2010-06-30 07:35:45 FILLED 6098663 Reset
    A problem with DIM it only has the products DIM downloads. I'd also like to have all products whether in use or not. Also I'm not sure if all products were re-downloaded via DIM. May be petty but it does provide a check list for various reasons.
    BTW I 'm on a MAC so the references to programs in the replies try including the platform.
    it works !! :) well done !
    ooops,, I forgot the output of the error.log
    7/6/2015 4:23:12 PM - Program started...
    7/6/2015 4:23:28 PM - Start test... (30 sec)
    7/6/2015 4:23:31 PM - StatusCode: OK
    7/6/2015 4:23:33 PM - StatusCode: OK
    7/6/2015 4:24:05 PM - Logged in... (30 sec)
    7/6/2015 4:24:35 PM - Logged in... (30 sec)
    7/6/2015 4:25:05 PM - Logged in... (30 sec)
    7/6/2015 4:25:07 PM - Program closed...
    Great! And thanks for testing. :)
    Just finished updating Account Manager, it should be working now as well. Otherwise, let me know.
    http://taosoft.dk/software/accm-daz/updates/accm-daz-a0521.zip
    You're welcome, glad I could help.
    It's working as well.The History tab populated correctly and it seems to be showing most of everything.DIM shows 772 items installed and accm shows 499.I assume this discrepancy maybe due to the way bundled items are handled by DIM.I'll have a look over the lists and compare them in a little later on tonite.
    edited July 2015
    Good. As for the difference in numbers between Account Manager and DIM it's because Account Manager lists products only, i.e. only one entry per product, while DIM lists the individual files for each product which may be more than one.
    Some bundles are not listed because they are not listed in the Product Library (Account Manager gets is data from the same json data as the Product Library). It's a bug, or inconsistency if you like, in the data. The individual products from all bundles should be listed though so in practice it's not a big problem. So essentially no single product, part of a bundle or not, should be missing.
    BTW, forgot to update the version info in the file, it's done now. I'll recommend downloading it again (just overwrite the old one), otherwise Update Check (under Help) will not work properly.
